How do I fix door latch
Hoover Nextra 6 how do I fix door latch
  • stephengolds May 10, 2009
    I have already taken it apart and tried tom put it back together several times to no avail
  • 916 Answers
OK, to fit the handle, the easiest way is to take the door off.
Once off, you have to take out any screws holding the inner and outer doors together.
Then, prise the two halves apart. Do this on a flat surface as the glass will then be loose.
Have a look at how the old handle goes together. Make particular note of how the springs are fitted as this is the hardest part to get right.
It's not the easiest job to do, but put the new one together and fit into the door, re-assemble the two halves, refit the door to the machine.
Posted on May 11, 2009
    President:
  • Washing Mach... Master
  • 2,923 Answers
Hope this helps.
Posted on May 10, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Machine wont sart
Your door lock/latch is broken, this is a common issue with front loading washing machines and the only way to fix it is to replace the door switch.
Mar 05, 2012 | Hoover Nextra HNF 2137 Front Load Washer
My Hoover Nextra 6 has its stop light flashing and the Start button will not kick off any programme?
It could be anything but one of the most likely things is a faulty door switch. What were the circumstances leading up to the fail ? Have you checked the filter? Is there any water in the machine?
Try unplugging it and leave it off for 15 mins.
difficult without any more clues...
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hi my Hoover Nextra 6 (HNL7146) is stopping mid cycle and the start light and delay start light are flashing 3 times every minute or so and the door will not open and door locked light remains illuminated....
the lights indicated a blockade, remove the front panel at the bottom to reveal a drain plug, the blockage is most likely at the back of the drain plug as the drain motor impeler sits directly behind the plug.
Oct 31, 2010 | Hoover Washing Machines
Cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
Jun 01, 2010 | Hoover AAA140 Front Load Washer
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
Hi John,
it has been a while since i worked on one of these, but I might be able to talk you through it, first make sure you have the correct bits to replace. i.e. the inside of the handle and the latch match the same that is on that you can see before you go any further.
using a torx size 15 I think remove the two screws on the door hindge, and then remove door by pushing up by a 1/4" then the hindge should pull away from the machine. using a torx size 10 then proceed to remove the four screws from the inside of the door frame, ease the door pannels appart and the glass bowl and lock should be exposed. there should be a further two screws holding the latch in place, just be careful when taken these out as they may be under load from a spring, note the positions of the latch and replace all back in reverse order.
Cheers,
Sep 07, 2009 | Hoover AAA160 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
