Question about Gateway Solo 5300 Notebook
I have problem with Infrared Device - Serial Cable using irDA Protocol. I lost wireless. Can You help me? The model of my notebook is: HP Compaq 6735s
  • masters1964 May 11, 2010
    what are you using the serial cable for
I Can't USE Hp C4103A , You have any idea ? or Need any software , Pls advise
This plugs into some models of HP printer for direct printing from an IRDA device, havent seen one used for years.
Aug 01, 2011 | HP (C4103A) Infrared Adapter
How to install games to motorola c650
hi there,
You can download ganes to you phone through different methods like: Over-the-Air (OTA), Infrared (IR), Bluetooth and Cable
1. For uploading through OTA: make sure your wap is well configured and working (each operator has different settings). Enter the .jad url of the game (URL of jad can be found below), then the phone will automatically download the .jad file. After the .jad file is downloaded you will be prompted to confirm the downloading of the .jar file. If you press yes then you can download the file and install the game. Volia! In general you should make sure that the .jar file will fit on your phone. Some devices like Nokia Series 40 (MIDP1) limit the .jar size to 64k, others will limit it to under 100k. Also most devices have a low limitation on the size of all games (midlets) installed, so you should always check the available memory and in some cases remove any old unused games. We have taken the limitation of each device into consideration and there's nothing to worry about here.
2. For uploading through Infrared: First you should get an IRDA peripheral and connect it to your PC. It's usually a USB device. Connect it and install the software.
Now there are two cases:
a. either your phone supports IRDA directly and in such case it's sufficient to upload the .jar file to your phone by right clicking on the file and use 'Send to' menu. Note that you should configure IRDA properly to connect to the phone. We are using the following configuration for SigmaTel USB-IRDA: "Infrared Transiver Type": SigmaTel 4000, "Min. Turn-Around Time": 1.0ms, "Speed Enable": 115200.
b. or your phone doesn't support IRDA directly but has IR. In such case you should use your manufactorer software like Nokia PC Suite.
3. For uploading through Bluetooth: Usually this is faster and easier than Infrared. Install your Bluetooth usb device. Right click on the .jar file and select the menu 'bluetooth device' inside 'send to'. You can also pair your device with your computer to make things faster. Once the .jar file is on your phone then you can install it
4. For uploading through cable: some phones don't have neither Infrared nor bluetooth support. You can use the manufactorer cable and connect it your PC (either USB cable or com cable). In such case you should also use a dedicated software for uploading files to your device
Please use the below mentioned link to find games.
http://www.zgroup-mobile.com/demos/Motorola_C650/index.html
thanks,
S.
Nov 20, 2009 | Motorola Mobility C650
Problem with stand by
If you are using an infared or wireless mouse and/or keyboard this is the problem. You can't go to standby when those devices are actively connected.
Oct 05, 2009 | Computers & Internet
Where is irda on hp pavilion 6700??
This model does not have irda. It has an infrared sensor on the front edge below the touchpad, but that's just for a remote control device. Full specs and a service manual are available on HP's UK site, and no reference is made to any model of this series including irda.
May 12, 2009 | Dell Inspiron 1525 Notebook
This model series does not include irda. Full specs and a service manual are available on HP's UK site, and no reference is made to any model offering irda. It only has an infrared sensor for a remote control device.
Laptop wireless won't connect to internet signal is excellant
double click on ur wireless icon in sys tray.wireless network status is shown ...click properties...in wireless properties scroll to internet protocol ...in internet protocol properties choose obtain ip address auto and choose obtain dns auto click ok..try to connect if no connection use repair ...you will see aquiring ip please wait.
Jan 13, 2009 | HP Compaq Presario v3000z Notebook
Laptop s infrared device, serial cable using IrDA Protocol problem
Sound has nothing to do with infrared devices.
The yellow exclamation mark that you see under the device manager is due to drivers of the infrared device not found or is not installed properly.
There might also be a possibility that the device is not getting recognized by the computer due to corrupted drivers so the drivers of the particular needs to be installed again with the CD.
Jun 04, 2008 | Gateway Solo 5300 Notebook
Infrared wont pickup my mobile phone nokia
Click HERE to go to HP to download your wireless drivers. Select your laptop model, then select downloads and drivers and choose your OS to get the drivers.
May 31, 2008 | Compaq Presario 700 470024-192 Notebook
Serial port
there used to be serial-to-USB converters available... Perhaps you can get one of those. Then you could try top setup your IrDA device (InfraRed, if you have one) for your ActiveSync Connecttion.
Sep 12, 2005 | HP Jornada 525 Pocket PC
Computers & Internet Logo
93 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
