Question about RIM (HDW-13019-001) Headset
Wired headset i plugged in the headset, tried to listen to music and it comes out the speakerphone, i cant find a way to switch it to headset, please help, this is killing me that i can't solve it.
0 characters
1 Points
Cant listen to music on my 975
The Plantronics Discovery 975 Bluetooth headset does not supports Advanced Audio Distribution (A2DP) and you need this Bluetooth profile to be able to stream music between two Bluetooth devices. The device you are streaming music from (example: cell phone) to the headset must also support Advanced Audio Distribution (A2DP).
Good luck from Headsets Direct!
Dec 07, 2011 | Plantronics Discovery 975 (8164001 P)...
How to connect my Lg c105 to nokia BH-108 Bluetooth headset?
hi i have a c105 i purchase a china stereo bluetooth headset through the internet now i paired its ok i can only make and received calls only i cant listen to music through my phone and memory card please help thanks. sanjay
Nov 18, 2011 | Headsets
Cant listen to music on my motorola i1 & plantronics explorer 233
Plantronics Explorer 233 Bluetooth headset does not support the Bluetooth profile Advanced Audio Distribution (A2DP). Your Bluetooth device and your phone both need to support A2DP profile, without this Bluetooth profile your devices are not capable of streaming music.
Oct 22, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Sony HPM-70 not working with music feature on phone
I got a "failed" when I tried to listen to my playlist, on the first song. I switched to a different song lower down the list, and then it worked. Not sure what made the difference.
Feb 06, 2009 | Sony HPM-70 Headset
Cant listen to music on my Blackberry Pearl using HT820
RIM has a new OS for the 8100 pearl (OS 4.3). This OS supports A2DP streaming which is necessary for listening to music with bluetooth headphones. The OS is out in beta version now and supposedly available on bit torrent. I hear that AT&T will release the OS for their phones in April or May.
Nov 06, 2007 | Motorola Mobility HT820 Wireless / Cable...
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
RIM (HDW-13019-001) Headset Logo
24 people viewed this question
Top RIM Headsets Experts
Brian Sullivan
Brian Sullivan
Are you a RIM Headset Expert? Answer questions, earn points and help others
