Hi,i have a hp pavilion f1523 monitor,the problem is that the main menu display and osd lockout keeps appearing on the the srceen for no reason,I've had the monitor for five years & never had this problem until the last 2 weeks.I've tried all the different options in the menu sections.this problem is very annoying.Can anyone give me any advice to resolve it?
-   Hi, I have a probelem with Hp7540 CRT Monitor.When the powered on.front LED is geting green but no display.(FBT is not working.) I have checked the voltages on the powersupply. That is ok. pls give me the solution for this.(prashanthaperera@yahoo.com) -   Guest
Mar 05, 2009
-   osd lock out show on the screen again agian-   Guest
Feb 06, 2009
-   the main menu of the monitor keeps appearing with no reasons and i tried every what i can but with no solutions. Help
-   amricool
Dec 02, 2008
-   hi, i have the same problem on my HP w2207h, the OSD lockout keeps on popin up on my screen, i tried holding the menu, didn't help at all, and the buttons are not stick either, can anyone help?-   thkimlong
Aug 28, 2008
-   mine reeeeeeally is working. I have the problem with the OSD lockout and NONE of my sound will work. Please help because I need the volume for a college presentation im doing next week!-   Guest
the above is wrong, press and hold the menu button for 10secs
Solution #2
posted on Jan 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To lock the OSD, press and hold the Menu button while the monitor is off, and then press the Power button to turn the monitor on. To unlock the OSD, repeat the locking procedure.
This took me several tries before it worked. So keep trying.
I had the same problem yesterday. I have a BENQ 22" flatscreen with Winfast PX7600 GT NVIDIA graphic card.. These were the symptoms. 1. Yesterday the "INPUT DVI" and "INPUT SUB D" message window kept popping up simultaneously and my monitor kept going black as if its switching between modes. After restarting a few times. That message stopped. but then.... THEN!!!!! the monitor display menu started popping up..repeatedly and I started screaming profanity at the computer. All the help page that I found online were about the monitor itself being faulty. Holding on to the menu button seemed to fix the problem..temporarily.
TESTING FIRST. My bf suggested that I hook up the monitor to my laptop and work on the laptop for a while and see if the same thing will happen..coz..if the monitor works fine..then..its not the monitor..its the driver..if the monitor still going stupid..then its the monitor...duh. 6 hours later BEHOLD!!! Its NOT the monitor.
SOLUTION!!!! !!!!!!REINSTALL THE MONITOR DRIVER!!!! NOT THE GRAPHIC CARD DRIVER!!!!!
SO!!! 1. find the driver for ur monitor. whatever brand it is. Mine was on the original cd with user manual and such.
2. go into to Control Panel>Sytem>Hardware>Device Manager
3 locate MONITOR and expand it. Whatever's there double click to open.
4. click on Driver tab, Click on Update Driver The hardware wizard might come up. can let it find it for u if u want. If it doesn't find it..then..in the next step,
5. click on Install from a list or specific location. The u specify ur cd-rom drive or whereever ur monitor driver is. then let it install. should be pretty quick.
6. Restart just to make sure....if it screws up ur comp. u can always do the Rollback driver by going into the same steps.
I know you said there were others that had the
same problem with the Main Menu coming up and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
Hi,i have a hp w2007 lcd monitor,the problem is that i'm constantly getting the main menu display...
(More)
Hi,i have a hp w2007 lcd monitor,the problem is that i'm constantly getting the main menu display and osd lockout appearing on the srceen for no reason -- what does this mean and how do I get stop this from popping up?
trouble getting screen on have to fiddle about with on off switch and power lead but screen stays on...
(More)
trouble getting screen on have to fiddle about with on off switch and power lead but screen stays on when it comes on
I have an HP 19" LCD Monitor that has an unstable image characteristic of a cold solder...
(More)
I have an HP 19" LCD Monitor that has an unstable image characteristic of a cold solder joint or a bad connection (perhaps cable). I am trying to figure out how to dissasemble it, but cannot find any screws. Any idea how to get access to the inards???
Mike Goodman
mmgoodman@verizon.net
Comment by Guest, posted on Feb 07, 2008
Hi,i have a hp fp 5215 monitor,the problem is that the main menu display and osd lockout keeps appearing on the the srceen for no reason,I've had the monitor for five years & never had this problem until the last 2 weeks.I've tried all the different options in the menu sections.this problem is very annoying.Can anyone give me any advice to resolve it?
Comment by Guest, posted on Jan 09, 2008
I am experiencing the same problem on my hpw22 screen. Have only had
the system for a year. This has been going on for a month and is
extremely annoying.
Comment by Guest, posted on Dec 01, 2007
I have the same problem that osd lock out keeps appearing on the srceen of my hp pavilion f1523 monitor. Is there any solution for it?
I have the same problem that osd lockout keeps appearing on the screen of my hp pavilion f1523 monitor. Is there any solution for it?
The OSD Main Menu keeps popping up and I've tried everything but nothing makes it go away.. I have the same problem and I'de REALLY apreciate some help. Thank you.
Comment by Guest, posted on Nov 10, 2007
the osd main menue keeps popping up on the screen and i tried everything and it wont go away
