Question about Dryers
Kenmore series 70 electric dryer will not heat up, but will rotate.
Kenmore series 70 electric dryer will not heat up, it will trun but will not heat up.
  • John Jun 21, 2013
    Different issue, will dry when set on timed drying but not on auto cycle
    Genius:
  • 1,122 Answers
Remove the back cover and check the heater box fuse and the heating element,do you have a meter?
Posted on May 11, 2009
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
No heat
If the unit is running but you are gettin no heat at all, you're heating element needs to be replaced.
Hope this helps...
Sep 14, 2009 | Kenmore 60172 Electric Commercial Dryer
Have a Kenmore 70 series electric dryer, runs great but is not getting heat? What should I do to fix this?
#1 make sure you have 240VAC at the dryer
#2 check the heating element and/or the thermostats
Jun 08, 2009 | Kenmore 62882 Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
do you get any heat at all? is the drum turning? if yes and yes you need to check the dryer hose all wall hole to see if it is clogged,clean both out and see if this helps,if no heat the main heater fuse might be bad,check that also,hope this helps you-mike
Oct 26, 2008 | Dryers
Dryers Logo
521 people viewed this question
Top Dryers Experts
