My 05 yz85 goes backwards when I put it into gear like it has reverse,i just built the bike the guy I bought the motor from said he was riding it just a few days before I bought it the only thing that is different on the motor is the electronics I put on from a 00 yz 80 can anyone help
SOURCE: '95 Yamaha YZ 125 clutch - stays in gear when clutch is pulled in
hey dude,, just thought id come in and give u some tips or 3,, i take it when u pull clutch lever in, and try and change gear it feels like your foot will snap b4 it goes in gear,, if that makes sense,, firstly mate,is to make sure the clutch cable slides freely ,easest way is to take cable off and just grab 1 end and make sure it isnt sticky,, if so dip one end of the cable in a bit of old oil ,,whilst holdin the other end ,pull and push the cable inner, this will **** up a bit of lubricant inside the cable ,, keep doin this each end till free to move, ,,next step if the cables ok,,, and may need help if u dont no,drain the oil out,,and as u r sat on the bike is to remove the clutch casing on the right hand side of the moter,where the bottom end of the cable goes,remove the casing being carefull not damage the gasket,,then u will see clutch plates and friction plates housed,, undo the 7 or 8 spring loaded bolts carefully take the first fibre plate out then metal friction plate then another fibre plate and so on,, wen u take the 1st plate out place that on the bench ,stacking each plate on top of one another, cause they have to go back in as they came out,,wen out,,u need a piece of wet n dry paper ,or fine emery,,and just wipe round both sides of the fibre plates taking the shine off them,as u put them back in,, put casing back on with a decent gasket,, oil back in cable on, make sure cable has no free play on the lever so wen u r about to pull lever in it bite straight away,, start her up, warm it up and try it,,any probs still il eat my shoe,, take care m8
SOURCE: yz 250 wont kickstart
Hi!
You obviously look after your machine and very sensible when laying up, however as you are probably aware 2 strokes rely heavily on compression, A. to produce excellent combustion and B. to draw fuel into the chamber. So when you try kick starting you can't get enough revolutions to draw the correct amount of fuel into the cylinder, where as you push start you constantly turn over the engine increasing compression slightly and bingo it fires.
Can you remember how when kick starting it before this problem the feel on resistance when kicking over? has it now become a lot easier? if so you possibly have worn or broken compression piston rings.
A compression test will reveal this, I hope this sorts your query?
Press the Blue button please for my FREE effort,
Thank You!
Paul 'W' U.K.
SOURCE: while riding my yz 125 it just died and won,t kick up again
Please rate the solution as a "FixYa" if able. Thanks!
the plates will stick to each other because of oil
check the clutch lever at the motor and make sure it is moving the arm that pushes the pressure plate and make sure it is moving
SOURCE: Yamaha YZ125 Clutch not disengaging
I would be more concerned with the stuck gear than the clutch, but we will start with the clutch.
The push cam may be bent or deformed and the push shaft may be bent. Assuming the ball bearing is in place, the cam and rod are all that can really go wrong. The rod slides out of the left center case. You will need to loosen the springs to get the left side cover back in place. Roll the rod on a flat surface to see if it is bent. I fear a bent shift fork is causing the gearbox to be stuck in third. Fix the clutch and then post a comment to get back to me.
Where u able to find out how to fix it? I'm going thro same problem
