Overheating and sometimes won't boot up
My laptop overheats and sometimes it won't boot up
  • May 11, 2010
    What make and model of laptop is it?
    Problem Solver:
  • 12 Answers
Take care with your laptop,. check the fan rpm clean it and make sure everything ok
Posted on May 10, 2009
Toshiba satellite pro A200 is heating up to over 50 degrees centigrade. how can I reduce it?
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 15, 2012 | Toshiba Satellite Pro A200-EZ2204X...
Tip
Laptop Tips: Overheating Problems
Overheating Frequent overheating will damage the motherboard!..becomes unstable, no display, hang-up and worst black-out or no power at all.
Symptoms: The laptop starts beeping, freezes, restarts by itself or shuts down after it has been on for some time, typically 10-15 minutes or more. If you start it again, it does the same thing after just a few minutes.
Troubleshooting: Most laptops overheat because the fan intake is blocked either from placing the laptop on a soft surface or by dust. In either case you will need to let it cool down before turning it back on (may take up to 30 min). If you suspect that dust is blocking the fan/heat-sink, get a compressed air can and try to clean it now (that will cool down the laptop too).
Sometimes overheating is caused by a fan malfunction. If the fan is completely stuck, the laptop will show an error message immediately after starting. However in rare cases the fan’s fins are just loose or broken and won’t move enough air to cool the laptop.
In either case you should try cleaning the fan(s) and heat-sink(s) with compressed air. That is best done outside, as usually there is a surprising amount of dust accumulated in there. If the laptop continues to overheat, you will need to bring it to a repair shop.
Also if you have dropped the laptop, the screws holding the heat-sink may have broken off. In this case the laptop will overheat in just a couple of minutes as the CPU has lost contact with the heat-sink and is not cooled at all.
Another one is moist inside the motherboard or corrosion.
If this troubles may arise and can't solve it yourself, bring it to certified laptop repair shop.
KUYA BOY LAPTOP
machinetosh of tipidpc.com
0912-6888500
on Apr 05, 2010 | Computers & Internet
Overheating problem of fujitsu E8420
Sep 29, 2012 | Fujitsu LifeBook E8420 PC Notebook
Sony vaio pcg-71318L overheating
Aug 30, 2012 | Sony Vaio PCG-71318L
Not booting, no power, overheating
Aug 17, 2012 | Sony VAIO VPCEE37FX PC Notebook
My gateway laptop automatic power off ? way
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 26, 2012 | Gateway Computers & Internet
Lenovo z560 cpu overheating problem solved
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
My laptop keeps turning off
Apr 29, 2012 | Computers & Internet
Acer 5730 overheat
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Dec 21, 2011 | Acer Travelmate 5730 Notebook
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
