Question about Boating
Motor runs but i put it in gear it die out - Boating
    Sergeant:
  • 187 Answers
If the engine was not winterized by adding a fuel stabilizer like Stab-All than it's possible that you have a varnish build up in the carburetor. I've had luck by adding carb and injuctor cleaner, run until you know it has reached the entire system and let set overnight. Its a long shot short of taking the carb apart.
Posted on May 12, 2009
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
You asked: My car was running find, a little rough. Took it to a friend to have the spark plug changed and wires. Degreaser was sprayed on motor then rinsed with water when done driving home about 1 mile,...
Try cleaning the throttle valve and idle speed control motor with throttle valve cleaner and then diconnect the battery for 5 minutes and drive it for a few days.
Apr 21, 2013 | Ford Escort Cars & Trucks
92 SL1 won't idle-wants to die without pushing gas-just put in new plugs
Remove, clean and inspect the idle control valve on the throttle body. These tend to clog up over time, or the stepper motor fails. Check this before anything else.
Nov 07, 2012 | Cars & Trucks
1974 225 runs good off idle dies when put in gear P. Lee
if it have a old type distrubutor with points and condenser I would put in a new condenser because they will let motor run at idle but when you try to drive it won't work.
Jul 21, 2010 | 1985 Dodge Ram 50
Need help on a 1995 Chevy Suburban. It will die at idle when it's up to running temp and in gear. I have to pump the gas peddle to keep it from dying. Just did a tune up and throttle body cleaning to see...
it sounds like the motor's tick over is far to slow when the car is put in gear if the tick over is say 750 rpm out of gear then it stalls when you put it in gear lift the tick over up to say 850 rpm the best way to set this up is have a friend sit in the car, warm the motor up, then get your friend to hold the foot brake hard on and put the car in gear, if it stalls bring the tick over up (in gear) till it dont stall,,,but hold the brakes hard on when your doing this,,,getting run over is not a nice thing to hapen to you and it wont make your day? you should feel a dit of a thump when you plop it into gear so hold the foot brake down when you do plop it in gear every time you do so, it saves the transmishion getting a thumping, all the things you have done to your car so far have only done it good, but why not change the oil and filter as well and know you have done the full monty on your car, and it wont need another service for another year or so?????
Jan 05, 2010 | 1995 Chevrolet Suburban
Motor dies instantly when put into gear.
i am arko iam looking for a softare for haking for mobile phone line & and memory
Dec 06, 2009 | 1996 Dodge Caravan
Yamaha blaster backfire badly
well i have had the same problem and it was a gear on the right side of the motor. the clip came off and the motor died. i did get it started to get it home but it backfired really bad the entire time. put the gear back on and has ran like a raped ape ever since. hope this helps.
Apr 03, 2009 | Sport & Outdoor - Others
1979 Firebird Esprit hard to start and keep running, dies in gear
it sounds like timing to me if it dies when you put it in gear.it can idle fine but when you put it in gear and it dies then you have timing problems
Jan 13, 2009 | 1979 Pontiac Firebird
1990 chevy full size van dies when you put in gear
check basics first - dist cap,rotor,plugs,etc.Then put a pressure gauge on fuel line and check reading to specs for truck. you may need a fuel pump
Jan 11, 2009 | 2004 Chevrolet TrailBlazer
Boating Logo
53 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
