Question about Epson Stylus Photo R220 InkJet Printer
Correcting print errors
I've printed the wrong information on to the titanium surface of some DVDs.  Is it OK to use correction fluid or will it cause problems in the DVD player or computer if it gets hot? Or is there something I can use to rub out the mistake?
    Problem Solver:
  • 16 Answers
Print a gummed paper label and be cover it
Posted on Nov 12, 2007
  • ptjims Nov 12, 2007
    I would not use anytype of correction fluid as it probably lead to degradation of the dvd
Won't print ie8 based receipts
It sounds like a configuration error please check all settings and confirm that they are all correct if not correct as necessary. It may also be a conflict between the 2 printers it maybe trying to print to both and cannot due to seeing 2 printers. If you have checked all your settings and they are correct try removing 1 printer and then if it prints on either singularly then it is a error that needs correcting on the settings for your printers to be able to be used together correct this problem and then you should have no problems. I hope this helps.
Sep 12, 2012 | Computers & Internet
Error memory when loading calculus made easy on ti-89 titanium
You may get Memory Error when you try to access an archived variables. From the other hand Memory Error message is displayed if there is not enough free RAM to access the archived variables. For correcting Memory Error message use the 2ND then MEM to check RAM free size and 2ND then VAR-LINK to determine the size of the archived variables that you want to access. As the third step for correcting this problem deleting unnecessary variable from RAM and archiving large variables or programs. By the definition, the RAM free size must be larger than the archived variables
Feb 23, 2012 | Texas Instruments TI-89 Calculator
I own a LexMark Prospect Pro 205. Sometimes when I print a black & white document there will be magenta printed over half or all of the paper. I've done the auto cleaning, but I'm still...
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to for online technical assistance.
Lexmark agents are prepared and able to help diagnose and resolve your issue. This may involve updating your printer firmware and/or replacing the printhead for your printer, at no charge to you, our customer. Installation is quick and easy for any customer to perform.
Your satisfaction with your Lexmark devices is our primary concern, and we are confident and committed to quickly correcting these issues.
Sep 01, 2011 | Lexmark Prospect Pro205 Wireless...
I have a Canon MP 210 printer, I put in a new colour print cartridge, now it shows the Cartridge is empty and when it prints the colour is only pink, I have checked that the print cartridge is installed...
I've heard of similar things happening and being corrected by opening its easy print software and trying to print something there to see if it's a driver issue. Also you can try manually correcting the color
Jul 25, 2011 | Computers & Internet
When you print out the activity report and under comment it says TX ECM what does that mean?
Transmission Error Correcting Mode was used. When the sending and receiving fax machines support this protocol, they are able to correct errors in transmission that occur. You can turn it off if it is causing you a problem, but it shouldn't be. It makes the determination about ECM capabilities during the initial synchronization. No positive response from the other and and ECM is not employed during the transmission.
Nov 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
"Wrong cartridge" error when in fact it is the right cartridge
On this machine it means the printhead is bad. QY6-0049-000 around $40.00
Jul 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Re dfx -9000
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications.
>Check cables as they can cause communication errors.
>Re-install the driver.
>Go to for more information & documentation.
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Epson Stylus Photo R220 InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
