Question about Sony KV-32S42 32" TV
Tv stuck on stand by
I have just got a tv 6 m ago and it wont come of stand by it was working be 4 i left and i come bk and it was like that
  • Gnarl Malone Nov 04, 2007
    Muted my TV-
    It shut off on its own - Standby??
    Now it won't turn back on - it just clicks when you try to power on.
    I've unplugged it for 12 hours or so. Nothing.
    I've pressed every button I can think of including the Standby/Timer button that's recessed next to the Power Button on the TV....
    I can't get it to turn on!
  • Anonymous Dec 16, 2007
    Same here... it the TV broken
Hey Kempy20--
Did you ever fix your TV ??
Mine's doing the exact same thing! I'm frustrated with it...
Put it on mute - then it shut off by itself after like half an hour -- and now it won't come back on.
Thanks.
Posted on Nov 04, 2007
SOURCE:
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
Doesn`t dispense soap right. soap left in dispensor
Hi
Try and disassemble the dispenser & check the wiring to the dispenser housing--
1. Disassemble the top plate assembly(Unscrew 2 screws on the back of the top plate).
2. Pull out the drawer.
3. Push out the DISPENSER ASSEMBLY after unscrew 2 screws.
4. Unscrew the nut at the lower part of the dispenser.
5. Disassemble the 4 connectors from the valves--
Wire Color
Blue Housing (OR-BK)
White Housing (WH-BK)
Blue Housing (GY-BK)
Red Housing (BL-BK)
6. Unscrew 2 screws from the back of the cabinet.
Hope this helps... Please post back if you need more information.
Daniel
Feb 17, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is the firing order on my 1992 Pontiac Transport. Also, which side of the block is cylinders 1-3-5 and 2-4-6.
FIRING ORDER 3.8L ENGINE IS 1 6 5 4 3 2 1 NOW CYLINDER POSITION.STANDING IN FRONT OF VECHICLE FRONT CYLINDERS LEFT TO RIGHT 6 4 2 BACK CYLINDERS LEFT TO RIGHT 5 3 1 FOR THE 3.1L ENGINE FIRING ORDER IS 1 2 3 4 5 6 STANDING FRONT ENGINE FACING DISTRIBUTOR LEFT CYLINDERS FACING YOU 6 4 2 ON THE RIGHT SIDE CYLINDERS 5 3 1
Jan 12, 2011 | 1992 Pontiac Trans Sport
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
Brand new came in the post 30mins ago plugged in to mains brilliant works fine played with the remote and turned off via remote. no wont turn back on tryed removing all power sources light flashes when...
It looks as if your battery needs to be charged. First charge should lasts long enough. Aproximately at least 6-8 hours. Then try to use it. I think it will work.
Regards.
Apr 15, 2010 | Katadyn Kata CC-191 Camcorder Shoulder...
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV won't turn on and red light flashes 6 times.
MINE DID THAT AND IT WAS THE THERMOSTAT FOR THE BULB
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Black wont print
sure. if you re lucky the generic ink hasn t destroyed the ph bk channel yet:
use skyhorse carts (http://www.skyhorse.net.cn ) who built good and reliable carts with a very good ink quality!
To get bk again:
press menu tehn start bk copy then fourtimes arrow up. machines will
be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts, refresh all tubes and ph channels with fesh ink and eliminates the air bubbles (quite a big prob within brother inkjet printers). When finished press 7 -6 -3 to
run a power purge. leave the maintenance mode by pressing 9 then 9. do run a test print.
If you cant see ANY bk the ph is clogged and cant be fixed any more. it needs replacing then.
Apr 05, 2008 | Brother Multi-Function Center MFC-240C...
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
