Question about Dell Inspiron 2200 Notebook
OVERHEATING 99 MALIBU
I HAD A HEAD GASKET JOB DONE X4WKS.MECHANIC TOLD ME TO DRIE IT FOR A WHILE TO QUITE THE NOISE. LOUD TICKING NOISE STILL THERE?ANY ANSWERS?ALSO CAR STILL OVERHEATING .COOLING FANS,THERMOSTAT?
  • ANGIECECELIA May 14, 2009
    what about the overheating situation?
Could be hydraulic lifters need cleaning, depends on car, engine, condition,it should tick like that if it didnt before. take it back!
Posted on May 14, 2009
    New Friend:
Try a new coolant overflow tank cap
Posted on Sep 13, 2015
Why is my car overheating?
Open the hood and find out where that loud sound is coming from first. Make sure the fan is not bent or blades damaged.
Aug 25, 2014 | 2002 Ford Focus
Keeps Blowing head gaskets
You need to strip the engine down and check the top of the block (deck) for cracks and have it resurfaced, Do the same for the cylinder heads, check them for vcracks and have them resurfaced. Use felpro gaskets.
Apr 08, 2017 | 2003 Chevrolet Malibu
2005 Chevy Equinox leaking oil out of exhaust manifold 107,000 miles. Just had head gasket replaced and heads rebuilt in which one was cracked. Mechanic puzzled by this because there is no smoke or odor...
Take it back and have the heads redone. Sounds like they left oil seals out or they didn't find a crack in the other head. It is very unusuall for oil to come from the exhaust and not smoke. And if the oil is coming from the exhaust gasket ,then the mechanic also didn't do his job right. This gasket should be tight, no air or anyhting else should be coming from between the engine and exhaust manifold. The never timed it is impossible, as it has to be timed to run. I would probably take it to anoher shop, explain what has gone on, get an estimate to fix it. And demand the other shop pay for it.
Aug 24, 2011 | 2005 Chevrolet Equinox
My car has a loud ticking noise coming from the engine, i was told it was a lifter is this going to cause my car to shut down?
Get an opinion from a mechanic. If it is a lifter a professional needs to adjust it because it must be within thousandths of an inch. You would need the correct tools and experience to do this job.
Jan 05, 2011 | 2005 Nissan Maxima
99 vw beetle, been overheating for a couple weeks off and on . put coolant in it . well, it was overheating bad and smoked and got real hot. so had it towed . called mecahnic to find out what was wrong and...
Check around, I'm sure that you can find someone that can do it for less money.
I don't know if the radiator was bad or not, so I can't offer advice on that.
If your mechanic charges $100.00 per hour or more, I can see where they get the quote from.
If you need more assistance, post a comment.
Where are you located?
Maybe we can help suggest a mechanic for you.
Thanks,
Tim
May 10, 2009 | 2002 Oldsmobile Alero
99 Chevy Malibu belt chirping noise problem.
one or more of the pulley's is defective, most likely the tensioner pulley, but check them all for wear and side to side movement which indicates a worn bearing, this causes the belt to not run true and chirp.
Apr 09, 2009 | 1999 Chevrolet Malibu
Head gasket job
wow .. nice mechanic ...
Dec 17, 2008 | 1992 Mercury Grand Marquis
Leaking coolant at intake gasket area but not into oil
$400 is a very good price for it, very long process. Took my mechanic 6 hours on my 99 Malibu, have to remove the head. $700 for my malibu
Dec 02, 2008 | 1991 Chevrolet Corsica
HELP
Coolant that goes down, but is not leaking visibly (check for puddles after parking), is probably a head gasket problem. Have u been checking the oil level? Is it going up, or not using as much as before? This is usually an indication of a bad head gasket, which allows the coolant to leak into the oil. The ticking noise can actually be the head gasket also. As the vehicle warms up, things expand, and any leak in the head gasket will close up and the ticking noise will not be noticeable. As time goes on, the 'ticking' will last longer, and get worse. Have u noticed if this ticking is lasting longer than when u 1st heard it? Let me know how u make out. countrycurt0
Sep 16, 2008 | 2004 Chevrolet Silverado 1500 Crew Cab
Dell Inspiron 2200 Notebook Logo
116 people viewed this question
Alun Cox
