Question about RCA TruFlat 27F520T 27" TV
T.V. problems Water got spilled down the back of my tv and of course it wouldn't work, it sat for 7 months and decided to try it, and it worked! so i unplugged it to move to another room where it could be used and plugged it up and it wouldnt work,so i unplugged it waited 2 weeks or so and plugged it back in and it worked, So i moved it again and it did the same thing, well its now working and sitting on the floor, I'm afraid to unplug it again because it probably won't work.  If I keep it plugged in it works just fine, once i unplug it, the power wont come on again for a few weeks....any suggestions????
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • do not worry.
  • just put it on for the whole day till you are at home.if any moisture is there it will dry out.
  • it may give you problem two or three times but it will be ok.
  • good luck.
Posted on Oct 12, 2007
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
My machine is stuck on rinse hold and child lock
Try unplugging for 5 min and plug back in.
if not working still order new interface stuck button sounds like
someone has been hitting buttons to hard or soapy water spilled on pannel
Mar 08, 2015 | Hotpoint Ultima WT960P Washer Front...
My daughter seemed to spill some pickle juice on the front of my sanyo flat screen tv it ran into the bottom where the power and channel changing buttons are now it is wigging out and changing channels and...
Spill a small amount of warm water and let it run down to wash out the pickle juice. Of course do this without the power cord connected. Let the tv dry long enough to be sure the water has evaporated before re applying power. Just might work.
Jan 03, 2014 | Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Panasonic th-42pz77u 42ed
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
but anyway 3 circuit boards seems a lot to be replaced in a row.
hope this helps!
Mar 20, 2009 | Panasonic TH-42PZ77U TV
UNIT TURNS ON AND RIGHT BACK OFF, KEEPS CYCLING LIKE THIS
I had the exact same problem. Googled and fond someone had gotten the tv to stay on by hitting "enter" on the remote as soon as they saw "AKAI" logo onscreen. That didn't work for me, but it got me holding other buttons down on the remote, all tried no go. So I then decided to tinker with buttons on the tv itself and VOILA! If I hold down the MENU button on the tv, the damn thing works perfectly! Every function still works from the remote too. So I taped the MENU button ON THE TV down, and all is well. After having the tv sit for 6 months, tripping over it during a move... now I have it back and no repair bill. Hope it works for you guys.
No charge... ;)
Jan 28, 2009 | Akai PDP4225M 42 in. Plasma Television
Tv will not go on
On my GE Tv/VCR Combo I had a similar problem. Try holding down the Power button on the remote for at least 7 seconds. This disengages the parental controls. I found this solution on another website after my tv stopped working after my 20 month old played with the remote for a while. This solution was not in manual. I am assuming that he held down the power button for 7 seconds to engage the parental control. Hope this helps!
Nov 10, 2008 | GE 19TVR62 19 in. TV/VCR Combo
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I don't know if this will help anyone else, but I sure hope it will. I had a similar problem with TWO of the three Sony 24" TVs I had bought together. TV#1 konked out a month ago; TV#2 messed up last week. So I called the Sony Service Center, and this very nice guy told me that a lot of times this problem occurs because the TV isn't plugged directly into the wall (most people plug theirs into a power strip/surge protector). When it happened to TV1, we hadn't been using TV2 so we just traded their locations and the "bad" one sat there waiting to be thrown out...and sat and sat and sat. Well, I was pretty hot when it happened again a month later to TV2. The service center guy told me to unplug TV2 and replug it in the wall after about 1 minute and turn it on. Nothing happened. Then he told me to plug in TV1 and turn it on. I did, reluctantly. And it actually worked!! I don't know if anyone having this problem has a week to be without their TV, but the guy said sometimes it takes up to a week of sitting to get it to work right again. So I'm waiting a few more days before I try to plug in TV2 to see if it works again, but for now, at least I've got one TV back. Here's hoping you all have the same experience. And then I guess we'll have to decide whether to plug back into a power strip (mine was actually plugged into my cable TV's DVR machine) or into the wall.
Dec 11, 2007 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
