Question about Microtek C593 15" Flat Panel LCD Monitor
Emachine destop not recognising acer lcd monitor
This secondhand desktop couldnt recognise flat monitor i attached to it. so i couldnt see if booting is ok. even if i have to find and download the monitor drivers online i couldnt because nothing shows on the screen except the 'no signal' message that came on briefly . how do i get the drivers, assuming this is what is lacking? the desktop is emachine. and the flat monitor is acer AL511
    President:
  • 2,992 Answers
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
Posted on May 10, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Only one vga works
IF NVIDIA VIDEOCARD .IT HAS TO BE ADJUSTED IN SETTINGS
Apr 17, 2013 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How to fix emachines netbook , model 250-1162 the 10.1 LED LCD screen will not turn on
Is it the screen or the laptop?
Have you plugged an external monitor to see if its booting?
If it is booting with an external monitor, you may need a replacement screen (google your model and replacement screen)
If its not booting, you could try this.....
http://www.fixya.com/support/r5335055-unable_start_windows
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
Emachine boots into logo screen.pressing F2 no response.
Did it work before?
Have you installed any new hardware or software?
Do you have any USB devices connected?
If so, remove and try again.
Try going into the BIOS to make sure the hard drive is recognised.
I hope this helped. Good Luck and have a nice day.
May 26, 2010 | E-Machines eMachines Desktop PC
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
Dvd/cd drive inoperative. System does not recognise a dvd is inserted.
look first go to your device manger and see if it is connected or not and if it is connected you will have A software problem if not conntact me again and i will tell you exatly what to do see first if your machine can red the dvd in the bois or not thx
Oct 26, 2009 | Acer AX3810B3801A Aspire Mini PC Bundle...
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
LCD monitor signs "no signal" on eMachines t3418
E-machines had had a long history of bad power supplies. I've seen many of these machines go bad and when they do they take out the video chip (Nvidea) with it, usually shutting down the whole machine. I've never seen one operable. You might be able to insert a video card.
Mar 23, 2009 | E-Machines eMachines Monitor E15T4
USB drive full
What happens when you connect the drive to the computer?
May 23, 2008 | Computers & Internet
Microtek C593 15" Flat Panel LCD Monitor Logo
230 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
Michael Deni
Level 1 Expert
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
