Question about Refrigerators
Defrost drain Our Frigidaire Gallery side by side is freezing the water when it defrosts itself. The water is not going out the drain and freezes instead. We used a hair dryer to defrost all the ice under the coils and around drain but drain has a rubber grommet on it and we can't figure out how to get water to run out. Is the rubber grommet suspose to come out?? Model number is FRS26ZGHW3 Or is there another drain somewhere beside under the coils because this one with the rubber grommet also has an aluminum pipe that goes down the middle of the grommet. When we defrost the ice it freezes right back next time it defrosts itself.
  • klc6564 May 10, 2009
    What is the best way to unclog the drain tube? Will leaving it unplugged for 24 hours be worth trying?
    Guru:
  • 1,524 Answers
That pipe is the drain tube. Must be clogged.
Posted on May 10, 2009
  • Robert Moller
    Robert Moller May 10, 2009
    That or warm water and baking soda with a few drops of bleach.
Unplug the fridge, defrost the freezer. You can speed the process using a hair dryer at the bottom of the freezer coils after removing the shelves, baskets and the 6 screws holding the lower half of the shield inside the freezer with a one-quarter inch nut driver or socket, then lifting that cover a few inches. Take note of which 3 screws have a plastic washer.
Remove the cardboard cover from the rear of the fridge. Take note of which 2 screws have a plastic washer. Vacuum out all the accumulated dust inside. Locate the rubber drain tube where it descends from the freezer section to the evaporation pan. Disengage the tube from the pan by lifting and flexing it. Remove the cementatous plug of wet dust from the bottom of the tube.
You can poke it out from the inside with a piece of #14 electrical wire or similar gently pushed down from above by curling it over the bottom metal refrigerant tube, but be gentle and avoid damaging the fins.
Alternatively, keyboard cleaning adapter kit (Google Shop Vac Micro Cleaning kit for an example) is the perfect size to suck out the plug from the outside, and the little wands are perfect to reach in and vacuum out the accumulated dust in all the nooks and crannies.
Have a sponge handy to clean up the stream of water that will flood out of the bottom of the hose when the plug clears.
Assembly is the reverse: ease the rubber tube back into its hole in the side of the tray. Install the cardboard cover, tucking the centre bottom lip inside the steel opening, and overlapping everywhere else. Install the screws, with the 2 plastic washers on either side of the water supply hoses.
If removed, position the white cover so the bottom lip is tucked inside the edge of the aluminium drain tray and install the screws loosely. The screw with the star washer goes bottom centre, no washers on the top two screws and plastic washers on the 3 in between.
Mop up any puddles of water, reinstall the shelves and baskets, plug the fridge back in and enjoy!
Posted on Jun 16, 2013
Coils behind freezer are frosting over then turning to water and leaking on floor
its suppose to freeze then defrost however I suspect you have a plugged / clogged evaporator drain line hole. in ur freezer, have to remove the bottom and back plate and have a look at it as well as check ur drain hose line going in and out
Apr 08, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
The freezer auto defrost puts a lot of water into the bottom of the freezer which in turn just freezes again. Then the next time it dumps more water there and it runs out the door.
There should be a drain hole or line allowing it to drain into a drip pan under the unit. You need to unplug the unit, melt or chip the ice out, make sure the drain is not plugged ( it could be plugged under the freezer.
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Coils freezing over inside a side by side
Most times when coils freeze up it is due to the failure of the automatic defrost circuit, specifically either the defrost thermostat or the defrost timer. Occasionally it is the drain under the coils somehow gets clogged and the water from the defrost cycle doesn't drain. If you have water in the fridge side or water forming ice outside the back panel in the freezer the defrost is probly working and the drain is clogged. YOU MUST GET ALL THE ICE OUT OF THE DRAIN. Hair dryer, hot water, etc must be applied. Water MUST flow freely to the drain pan below.
Sep 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Aug 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
258 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
