Question about Karcher 2500 PSI Pressure Washer
Karcher 620m runs but will not pump water - Karcher 2500 PSI Pressure Washer
  • 62 Answers
The pump that connects to the motor could be bad/and or loose
Posted on May 10, 2009
Most likely the inner head gasket has blown allowing the high pressure side to recirculate to the low pressure side... making the cleaner pump nothing much out the nozzle. This is a very common problem with this model.
Posted on Sep 22, 2012
2 Suggested Answers
SOURCE: what oil grade is correct for Karcher 620m pump?
I don't know either. Anyone got an answer?
Posted on Mar 06, 2011
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
Karcher 620m wont work at high pressure
what you describe indicates a problem hose or block nozzle jet
if it doesn't play up with a normal nozzle then it is not the hose or jet but that particular wand and nozzle you are using
do you have a sufficient inlet water supply for the pump
May 01, 2017 | Karcher Garden
What oil grade is correct for Karcher 620m pump?
Jan 07, 2011 | Karcher Garden
Need manual for karcher 620m
Hi. Please click here to download the manual.
Let me know if you need further assistance. Thank you for using FixYa.
Jun 05, 2010 | Garden
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Jan 08, 2008 | Washing Machines
Karcher 2500 PSI Pressure Washer Logo
1,319 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
