Question about AOpen Computers & Internet
I have an older AOpen keyboard (2004). I believe the model number is TC E1.I don't have a layout of the keys with an explanation of their functions. Is there a way to find this information. Mel
4 Suggested Answers
SOURCE: Apple Pro keyboard model #M7803
I was researching this same problem, and just read on another site that you may be able to use shift-clear, which worked for me. good luck!
Posted on Jun 04, 2009
  • 218 Answers
SOURCE: Have no problem, just purchased
You should be able to find the information you're looking for in the "User's Guide", located here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1073769712&rpn=PA1262U&modelFilter=310CDT&selCategory=3&selFamily=1073768663
Posted on Jan 04, 2010
Current009
  • 135 Answers
SOURCE: I need an explanation as to the secondary function
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Posted on Jun 16, 2010
Testimonial: "Just what I needed to know. Very timely and helpful. Thanks!"
IS THERE A MANUAL FOR THE k120 KEYBOARD AVAILABLE , SO THAT I CAN FIND WHAT ARE THE LEDS ABOVE NUMBER PAD MEAN AND ALSO THE F KEY FUNCTIONS?
There is no manual specifically for this keyboard: The following is a keyboard diagram which may answer most of your questions: The small mode button above and between the F4 and F5 keys switches between Function and F-Key modes for the traditional Function keys. Experiment a bit when you are not working on something important.
https://secure.logitech.com/assets/42401/us-keyboard-layout.pdf
Also, check
http://support.logitech.com/en_us/product/keyboard-k120/faq
Jul 24, 2017 | The Computers & Internet
Do you have a descriptions of keyboard on Windows Vista There are keys with letters and numbers with icons on them . I would like the description of the keys.
Hi.
The layout of keys can differ with different model and make laptops. The keys with letters and numbers on them are used with the Num Lock key, if you press the Num Lock key them keys will type numbers instead of letters. If you press that key again they will type letters as normal.
The keys with icons on them are used with the function (Fn) key. That means that you hold down Fn and and use the F keys to adjust things like brightness, volume, mute and Wireless radio etc.
If you are wanting a full breakdown of your laptop models keyboard then i suggest you download the user manual from HP support website. Link below.
http://www8.hp.com/us/en/support-drivers.html
Regards.
Apr 28, 2011 | HP Computers & Internet
How can i put a layout to my friendster
just search friendster layout and there's a ton of result of that im sure..
Feb 02, 2011 | AOpen KB-858 107 keys layout, 3 Windows 98...
How do I use the function keys to engage the battery charge function - specifically what is the fn key? I don't see in on my keyboard
The function keys are toggled between their different jobs by a key labeled F lock or there is a fn key at the bottom of the keyboard. I was not able to see a keyboard layout for your model, but look for a key near the <alt> <windows> and <ctrl> keys that says fn or the like. It functions similar to a capital letter, press and hold the key, and press the desired function key.
Nov 19, 2010 | Dell Inspiron 1525 Laptop
I recently purchased a Logitech MK710, but I use the Divorak keyboard layout, not the traditional "QWERTY" layout. Consequently I need to physically remove many key covers and rearrange the...
no no no
you go to keyboard possibile properties ) click on orientation, click on american or english or what ever you want , click apply and it changes the keys correctly for you
qwerty is american and what you have is probably english as they are different in layout
Apr 03, 2017 | Logitech Wireless Keyboard and Optical...
Sometimes the keys that have white and blue writing on them will only respond blue. How do i get them to respond as white instead of blue keys?
You have a FNC key on your keyboard. Since it is a laptop, your keyboard can not have all the keys that a normal keyboard has. This is handled by making some keys perform two or more functions. Thus, the alternate key use if the blue keys (function key is depressed). You will pribably find that there is a light labeled as FNC where you see your caps lock, num lock etc.. it sounds to me that you have your keyboard in alternate function mode so that the keys are performing the alternate functions (probably the numeric keys if it is a normal configuration..).
Thanks!
Stan Skaggs
Oct 19, 2009 | HP Pavillion G50-111NR Notebook
I have an acer Travelmate 2500
is the second function numbers ?
Robert
Aug 27, 2008 | Acer TravelMate 2500 Notebook
Asus ee PC 900 keyboard
Please don't multi post the same problem.
Your keyboard will obviously show the wrong thing still but if you go into settings, personalization, keyboard layout you can then change the layout.
I'm afraid I don't think that you can buy a new azerty keyboard separately as an eee pc spare part. Maybe you can if you contact asus.
Hope this helps,
Mowcius
Jul 23, 2008 | ASUS Eee 4G Notebook
Asus eee PC 900 keyboard
Hope this helps,
Mowcius
AOPen O35g to usb port
sometimes adapters do not work.
this might work
start computer without mouse. you may have to work with keyboard tab key as you press tab key you should see the icons highlighted install drivers plug in mouse to usb if lucky O/S will recognize mouse and setup
Jul 17, 2008 | AOpen (O35G)
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
