A/C Fuse constantly blows.
Fuse keeps blowing and condensor clutch does not engage.
  • 38 Answers
You have a low voltage short that occurs whenever you try to call for cooling
Posted on May 10, 2009
I have a husqvarna LGT2654 it blows fuse brought in for sev was told to clutch shorted but unplugged pro and fuse still blows fuse any ideas
If the tractor blows fuse while the engine only is running, you may have a hot wire grounding out. If the fuse blows when engaging the blades, the PTO switch or electric clutch is the problem.
Aug 01, 2017 | Husqvarna Garden
Hi everyone :) My AC is not blowing cold air and the AC Clutch fuse breaks once I turn on the vehicle. Can anybody help me?. Thank you
The fuse blowing most likely means that the A/C clutch is shorted out or drawing excessive current due to malfunction. If the clutch fuse blows, the clutch won't engage, and you won't get any cold air. You need to have the compressor clutch serviced.
Jul 25, 2016 | Cars & Trucks
Even with the mower not running when i pull the switch to engage deck it blows 20 amp fuse
Kelly, ray g. nailed it, First be sure it is only to be a 20 amp fuse, The wires to the clutch that drive the deck will be broke or bare shorting out on each other or on metal, wire are quite commonly broke by the clutch plug or close by. what you can do is carefully follow the wire from switch through the system and look for damage or bare spots, pay special attention when wire runs through frame/body holes and any where it could rub on metal or moving parts. Check the attached links,instruction and guides,4th link see Randy T. reply in forum, has good test method for your problem. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Craftsman 917 273631 Fuses keeping blowing when blades are engaged
CC1042 with Kohler Keeps Blowing Fuse when PTO Engaged
Blowing Fuses
265 blowing main fuse when engaging PTO
Apr 25, 2016 | Garden
Air condition blows hot air
this could be caused by the fact that the system may be low on refrigerant, not enuff and condensor will not allow the clutch to engage.
Apr 18, 2013 | 2005 Scion xB
EXmark mower blows fuse when deck is engaged.
try checking the wires from the switch that engages the mower deck. if there is a wire grounding out sumplace when you kick it on it will keep popping the fuse no matter what. id say its a short.
Mar 16, 2012 | Craftsman Garden
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
A/C blowing hot air on 2002 Ford ZX2
first id check see if hoses where it connects have oily residue on them , if yes then o-rings/hoses are leaking and need replaced, usually compressor wont kick on if low refrigerant.
also check fuse box, sometimes a fuse will blow, need replaced , kind of rare but happens. might also look aaat where there are high/low pressure sensors screwed into condensor by firewall , passenger side usually. use a small wrench and tap very lightly and them sometimes very rarely they stick. if so id replace.
Mar 29, 2010 | 2002 Ford ZX2
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuse keeps blowing out
rol down window instead! ok kidding, does fan alone work ok? it might be your clutch shorted drwaing too many amps. its wheat engages your compressor when you turn on ac.
Mar 30, 2009 | 1997 Chrysler Sebring
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
