How to conect iPod to Bose Lifestyle 12 Series II System
Can I conect iPod to Bose Lifestyle 12 Series II System
I connected my iPod with the same Bose with a cable you can get from Radio Shack for under $10.00. Please forgive me for not knowing the technical terms but one end has the male red and white plugs (audio composite)while the other is a single malplug that goes into your iPod. Just pick an open spot to plug it into the back of the Bose (Tape, Aux, Video) adn you are on your way.
http://www.radioshack.com/search/index.jsp?kw=ipod+cables&f=Taxonomy%2FRSK%2F2032058&categoryId=2032058&kwCatId=2032058
Found the link to the radio Shck site and the cables.
Hope This Helps.
Posted on Jun 05, 2009
How to open Bose LS12 series II music center to trouble shoot
the black box has a plastic lever on top, turn it with a thin screwdriver, then pull the plastic cover, if the black box has 2 screw on botton apart them.-
May 12, 2012 | Bose Lifestyle 12 System
How do I setup and new samsung led with a 12 year old bose lifestyle 25 series II?
... According to their manuals. The TV is new so it should cover that end. Bose.com covers the other.
May 14, 2011 | Bose Lifestyle 25 System
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
How do i connect a ipod to a bose lifestyle v30 system
You can connect your iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
__________________________________________
Download Bose LifeStyle V20 User Manual
Jun 07, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Same same here!
Any readily available Stereo RCA to Mini cable. These cables are a in stock item at any electronics store.
Plug Mini side of cable into ipod headphone jack and the RCA side of the cable into any available input on the Bose system, match color for color, Red to right and White to left. Select that input on your Bose system and use the ipod as normal. This is the cost effective solution.
The better choice is to use a after market ipod dock system such as DLO http://www.dlo.com/products/homedoc_dx_Prod.tpl there are several levels to chose from all the way to HD outputs. These units can put your ipod display on your TV screen.
Jun 07, 2009 | Bose LIFESTYLE 28 Series III System
I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Feb 03, 2009 | Bose LIFESTYLE 28 Series III System
Lifestyle 12 receiver vs lifestyle 12 II
yes will work just fine, a slight difference in the output gain from the control baord, but in almost all other cases you wont know the difference. just make sure especially if you intend to use the old cd unit with the new bassbox that if you connect the digital source to to (say dvd player) that you initially use bose remote to turn on bass baox and set volume.
Jan 17, 2008 | Bose Lifestyle 12 System
Lifestyle 12 speaks - new HDTV
mount to wall, brackets available to purcahse on loads of on line sites. and from bose direct cost 5 dolurs to 50 dollars eack depending how fancy you want to be.
would recomment also distancing the left right satellites as you will be amazed how much improvement in sound is gained from a well defined centre channel.
also if you want to be really smart. its really not necessary to see the centre satelliet and it could simply sit of the stand behind the tv. with no problem. plus you could use the tv audio input to make the tv as a centre channel. you would be surprised how well that works. make sure you disable the tvs steroe function or your surround sound will not sound too surround....
finally if you have lifestyle series II make sure you conect the 5.1 input to the bass box to your tv. and get rid of the bose cd player , put it out of sight, and loose the remote. will work even better than it did before !
Jan 02, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 8 no display
I had the same problem and Mark Burgess at http://forum.ecoustics.com/bbs/messages/1/125990.htm helped me out, change the 4 capacitors in the lower board, lower left side and that will solve the issue.
regards
-Luis Carballo
Nov 20, 2007 | Bose Lifestyle 8 series II System
704 people viewed this question
 Grubhead
Grubhead
