most pairing when asked by the device requires a 00000 passcode but you need to set the jabra and the iphone up for pairing here is a link for jabra the iphone should see it when the jabra is set to set up mode.. http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Okay, I had the same problem of Jabra Journey not talking anymore, 'voice on connected "etc. And instead it only made sounds like bing bing... Here's the answer and its so simple! Turn the unit off with the slider off/on switch, (symbols are - or o). Then, press and hold the button at the very end of the unit, (symbol looks something like sound waves), while sliding the power back on. That's all there is to it and you'll hear it start talking again.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
I had the same problem and found the user: Splut wrote in another problem the following solution:
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000.
I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you.
DIVA08
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
