Question about Compaq Presario 700 470024-192 Notebook
Additional memory - speed?
When I purchased my laptop it already some aditional RAM I think it's got 256. However, compared to my desk top it's very slow so I'm wanting to add more RAM as I believe that will enhance its performance? And my question is, if I buy some additional memory ie another 256 (making a total of 512 will it  cause a problem as when I've read the bumph it says that this particular model only supports 384? And if I buy another 128 to make it 384 will I notice any difference?
    President:
  • 2,961 Answers
Yes even the 128 increase will be noticeable, but to be sure of what your system can take visit the crucial site and download the scanner tool to tell you what the memory capacity is
Posted on Oct 12, 2007
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Computer has crashed. Everything gone off desk top and program list. Everytime i start computer it opens data recovery window and goes through a scan, it says hard drive space less than technical...
hello, usualy in this cases the memory is the problem, any way if u already buyed 1GB ram ,wait until u get it and change it, let hope will resolve all problems, u can get an UBCD live cd and make some hdd and memory tests from it, and then if still dont work u can go to a specialst.
because will be a lose of money to go to a center now after u already got the RAM
this is my advice because is imposible to some one to resolv this whit out beeing infront of laptop
best regards
Sep 22, 2011 | Dell Inspiron 6400 Notebook
I have a Packard Bell desk top PC In 2006 I Installed windows vista I noticed I needed a 512 ram as I had 256.I bought a 512 ram I knew were to install It ,I took the 256 ram out and carefully put In...
You put in the wrong type of memory. Put the old 256 back in the computer should power on with no beep code(or all good beep). If this is correct make sure to obtain the same type of memory as the 256. Also both slots must have the same RAM. You cannot have a 128 with a 512. They should both be either 128 or 512.
If you are using Vista you should have a minimum of 1g RAM.
Jun 08, 2011 | Computers & Internet
What is the maximum RAM, I can add to my DDR1 Dell PC computer Desk top?
The maximum memory that your laptop can allocation is 256 mb only. Since there are two slots you can put 128mb for each slot. Sorry, you cannot use memory from your desktop to your laptop. You can view the actual memory you can use by following this link http://www.memory-up.com/Memory/SonyVAIOPCG-FFG448.html
Jan 31, 2011 | Sony VAIO F808K Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I need to know the motherboard capabilities regarding the type of ram as well as size for the Disney Dream Desk I have in order to purchase the correct ram. About 224 of the 256 is already taken and the...
This is made by Medion
The ram you need is ddr333 also called pc2700.
It says you can install a maximum of 2gb.
Try ebay for cheap memory upgrade
Jul 17, 2010 | Computers & Internet
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
SPEED OF LAPTOP
What is running in the background. If xp go here Stop Unnecessary Services Batch File .
Oct 10, 2007 | Compaq Armada E500 Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
