Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
I connected the controller but it shows that it is not connected
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
First check your ports by trying other devices ....if it works, then check the cable on the controller.....
Posted on May 10, 2009
    Problem Solver:
  • 12 Answers
In some cases your console won't detect the Bios of the analog
Solution:Upgrade your consoles bios
Posted on Jun 29, 2009
Wireless icon showing not connected when i am
there is an option to disable the icon when connected and/or disconnected
check in wireless network connection, in control panel in network connections. there is a check box to show in task bar when connected and one for disconnected.
Apr 25, 2012 | ASUS Computers & Internet
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have an F11 code
Washer will suddenly stop with 1 minute left on cycle and shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection.
Jan 24, 2011 | Kenmore Elite 45986 Front Load Washer
The computer does not show the internet connection in the monitor. Before I reinstalled the windows it shows the message: no connectivity or limitated connectivity. The comcast modem was damaged so they...
Even though it does not show the connection on your monitor, the connection may still be working. Did you post this problem from the same computer? If yes, then you are fine.
Dec 29, 2009 | Dell Dimension E510 PC Desktop
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Wont usb connect!
go into device manager and update the drivers on the newly found hardware. If they are already installed used the disc to re-install from device manager.
Then add the application on whilst the item is discomnnected
Re-connect and launch application. Should work.
Dec 24, 2008 | Logitech Harmony 525 LCD Remote Control
Can't Connect Wireless Controller to PC
You cannot connect it unless you buy the M$ wireless dongle for your pc.
Sep 19, 2008 | Microsoft Xbox 360 Controller
Xbox 360 guitar hero 3 controller [wired]
try restarting your xbox, make sure your controller is properly connected, and try replacing the battery.
Aug 01, 2008 | Microsoft Xbox 360 Controller
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
326 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
