Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
I keep getting paper jams on my Canon MultiPASS MP730 All-In-One InkJet Printer. Is thier a way to fix it?
  • Bob Kitaji May 11, 2010
    Can you give me an idea what you were doing or what happened before your started having the problem?
  • 4,041 Answers
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
"ink catridge jammed"
Hello there
Feb 19, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
Nov 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam
see what you gotta understand
is that right next to the
rollers that pick up the paper
are paper sensors so if those
sensors have been damaged take
a cotton swab dip it in water.
clean the rollers where the
paper is taken in from and
also clean the carriage rod
along which ur cartridges
move(metallic rod).
now if this still does not resolve the issue can be a hardware malfunction with the printer and you may need to get it replaced or changed
Jun 15, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon mp730 paper jam.
Hi
The manual is available in this site .....Follow the direction from it to access the paper path .....
http://www.fixya.com/support/p360581-canon_multipass_mp730_all_in_one_inkjet/manual-10204
Feb 06, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
PAPER JAM
Open your printer and check inside in all compartments where the paper goes thru. After that use some dust spray to eliminate all possible little pieces of paper.
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printing problems
When I select print I can only get color it wont do black and white.I have went through all the cleanings .It sometimes says cartriges are jammed but they are not.The ink is full Im not really sure whats going on with it.
Its a Canon MP730 Thank you
Aug 21, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
False Paper Jam
I have a problem with a canon printer MP460 its saying I have a paperjam but there is no paper to be seen cartridges move back and fore manually with ease please help
Nov 04, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
Canon MP730 "carrige jam" error frequently
This error will generate when the printhead holder cannot move. This is usually due to a paper jam. Clear the jam (or whatever might be obstructing it) and then press "Resume". Do NOT try to move the printhead holder manually. As for cleaning your printer, here is the owners guide from Canon. http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 Download the last link on the page. Hope this helps. Good luck.
Jun 28, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
202 people viewed this question
old marine
old marine
