Evaporative cooler not getting water from water line
I have a Mastercool evaporative cooler and the water is on, but not getting to the cooler on top of my house. Not sure why?
If you are not getting water to your cooler, check your water valve where is connected to supply line. Check your supply tubing for kinks. Check your float for a bent rod or internal stoppage. Here in El Paso TX we have a lot of lime and calcium in our water that can cause blockages
Posted on Aug 14, 2013
  • 8,220 Answers
The pump is probably gone. the way it works is a float allows the water level to stay the same in the reservoir so check that. Water is pumped up to the hoghair and trickles down into it. A big old blower pulls the wet outside air into the room. We call that one a swamp cooler down here on the gulf. Go outside and spray some water on the unit to cool down the house till you can get the pump replaced.
Posted on May 10, 2009
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
My evaporative cooler is only blowing warm air through the home, even though the water is on and all windows are open. Can you help?
Check if the water is getting into the unit. check if it is pumping any water over the filters. cooler will meet its limits at 90% humidity plus
Dec 31, 2010 | Mastercool 67471 Evaporative Cooler Air...
Bonaire evaporative water keeps running whne the unit is turned off
I would check electric solenoid valve on water line to make sure it is shuting when power is off to blower. Some of these valves can be taken apart and cleaned if it has debris stopping valve ffrom fully closing. To do this shut power off to unit, shut main water supply to cooler. Usually there are four screws holding top cover on valve remove these,remove cover and clean valve. Reassemble making sure that cover gasket is in good condition and properly placed. Turn water and power back on and try unit. Hope this helps you. Thanks
Nov 11, 2010 | Mastercool 67471 Evaporative Cooler Air...
I want to adjust the float on my mastercool, how do i reach the float.
To adjust the float you have to try by bending the arm ever so slightly until the water shuts off on its own. You don't have to bend it too far, it won't get enough water. If this doesn't do the trick you need to get an evaporative cooler float from your local hardware store, they can best tell you how to change it because you will have it visually in hand.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Mastercool 67471 Evaporative Cooler Air...
How do i drain a mastercool of water manualy?
Remove drain pipe from water pan. You can usually turn it counter clockwise. When drained, clean with fresh water and replace pipe buy placing pipe dope or teflon tape to avoid leaking.
May 05, 2010 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
The Mastercool cooler is not cooling. It is only
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Jul 11, 2009 | Speed Port-A-Cool 16" Evaporative Cooler...
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
277 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
