Packard Bell EasyNote BU45P 059, the micro and headphone jacks have bad connections. e.g. no connectivity with micro and sometimes no connectivity with headphone.How can I repair the jack internal parts to have good connection? Before I would try to dissassemble the whole cover, may be it would be good to see a service manual or get an expert advice..... thanks
Why is sound gone on packard bell easynote
Click Start/Control Panel/Hardware and sound, and adjust your computer settings. Sounds like maybe your Playback device could be set wrong. Should be "Speakers" if you are using speakers or headphone.
Jul 20, 2014 | Packard Bell EasyNote E2 316 Notebook
Hi. I having a problem with my loptop Packard Bell EasyNote R1910. Sometimes its can't start up. it power up per several times. When it starts he's working perfectly but when i move it it's restarting or...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 20, 2011 | Computers & Internet
Why wot it let my packard bell easynote r4250 connect to a tv through a VGA ports
There is not enough info here. Many things could be wrong. Are you actually plugging the VGA cable into the VGA port on the tv or computer? Does your tv even have a VGA input? Is your tbs input switched to the tv? Please contact me with questions.
Feb 28, 2011 | Packard Bell EASYNOTE R4250 COMPATIBLE...
I have a packard bell r 6512 laptop I lost recovery cd. so I want drivers for the above said laptop. How can I get.
you can to to there old link here --->ftp://ftp.download.packardbell.com/NOTEBOOK/EasyNote%20R6%20series/Driver/xp/
Dec 04, 2010 | Packard Bell Computers & Internet
I have two laptops - a Sony Vaio and a Packard Bell Easynote. The Hitachi HDD connects fine to the Sony via the USB - showing immediately in 'My Computer'. However, this is not the case with the Packard...
You might be using a lower version of OS in your packard bell computer. You will need to download and install a device driver for your hitachi HDD. Im not sure of the HDD model that you have but you can try searching the driver for the packard bell Operating system
Oct 25, 2010 | Computers & Internet
How do I know if my packard bell easynote R4250 is dead?
If the laptop is more than two years old. Time to replace the battery. The power meter is not a reliable way of seeing a bad battery. If just one of the cells in the battery is bad it will not run your laptop , and the meter still would show 100%
Jan 07, 2010 | Packard Bell Easy One Silver 2120 Notebook
How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Oct 22, 2008 | Computers & Internet
Internet Connection - Operating System drivers for WinXP (Packard Bell EasyNote E2310)
you have to install the original windows in able to perform the computer well and to work the driver properly, sometimes if you install the pirated xp windows the driver wont work properly specially the wireless network.
you can find the driver thru the internet dell website.
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
