Question about Matrox Millenium MGA - Graphics adapter - MGA 2164W - PCI - 4 MB WRAM - retail Graphic Card
I installed window xp when my display driver installed my screen is then flicering from that time.
  • 60 Answers
Try to boot into VGA mode by hitting F8 as soon as POST boot screen has disappeared. If there is a possibility to uninstall through Add/Remove programs, do so. If not, then go to Device Manager and uninstall the driver there. Reboot and let Windows detect the device for itself. If it finds a driver by itself, let it install.
Posted on May 10, 2009
My emachines g720 screen is flickering
sounds like a bad sync.
1]start windows in 'safe' mode::if my guess is correct it will clear.2]if you can get to display properties [graphics options in Windows 7]; I suspect that the refresh rate is set too high.3] bad monitor or cable [may reseat and it will clear]
Feb 19, 2012 | Computers & Internet
Installed Nvidia gt210 card. Running XP. Windows runs fine when not using the Nvida drivers, screen displays correctly. Install drivers and screen display is scrambled. Looks like a rainbow. Uninstall...
Hi, you can download the latest driver here at nvidia:
http://www.nvidia.com/object/winxp-280.26-whql-driver.html
Maybe the videocard has a defect.
Try to change the card with a newer one.
Or the driver you have downloaded does not fit your system.
Try also windows update.
Hope this will help you
Aug 21, 2011 | Computers & Internet
I have a compaq presario 2100 laptop with a 15" screen but after putting a new harddrive and installing windows xp which thats the windows it originally had but the screen is only about a 13" screen that...
Please reinstall your display driver. Windows is unable to correctly identify your display dimensions. Once you install your display driver, you screen should be normal.
Nov 11, 2009 | Compaq Presario 2100U Notebook
I bought a second hand NECVALUESTAR VT900/3.Ive install a Windows XP Pro sp3 from its old Version Windows XP home edition ive installed everything find but theres a Black space on both side of the screen...
check your display drivers. whenever you install a new OS, 99% of the time you will need to reinstall a few drivers.
  • open system properties
  • press hardware
  • Device Manager
  • Look for highlighted entries
  • right click and hit update on highlighted device
Sep 13, 2009 | NEC Versa VX Notebook
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
My problem is the displayed windows on my monitor/screen
Press the F8 key when windows is booting up from a power off situation, select "safe Mode" you should get a Display then,(NO Video driver(except windows generic) driver is load in safe mode). Set your display to the LOWEST resolution.. Reboot. See if you have a display with the driver set Low. If so, increase the resolution on level at a time until you encounter a problem. If you do not select Yes when windows asks if you want to keep this display setting, Windows will revert back to the last setting you selected yes for.
Apr 12, 2009 | Microsoft Windows 2000 Professional for PC
Display problem in windows xp
Make sure the drivers for both monitors are installed. Update the driver for your graphics card. Hopefully this will fix your problem. Good luck.
Dec 22, 2008 | Microsoft Windows XP Home Edition
I have a video problem
its been a bad install of the drivers, boot into safe mode and uninstall the display drivers, reboot the machine and it should reinstall the drivers itself
regards
Nov 26, 2008 | Sony (A8045060A) Motherboard
Display blanks after installing drivers
Try the final AMD Display Driver (version 8.31) downloaded directly from AMD for the Radeon 9250 series running in XP. It will be several years more recent than any provided in Windows XP (by Microsoft), and may just fix your problem. The fact something causes XP to identify your Radeon 9250 as a 9200 Pro shows that something is not right. You might also want to launch Device Manager, use the option to show hidden devices, and delete any "ghost" video cards. I suspect a 9200 Pro may be a ghost, which could be causing problems.
Sep 13, 2017 | GeCube Computers & Internet
Problems in Downloading & installation of Driver 640c.
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
Jul 26, 2008 | HP DeskJet 640c InkJet Printer
Matrox Millenium MGA - Graphics adapter - MGA 2164W - PCI - 4 MB WRAM - retail Graphic Card Logo
163 people viewed this question
Top Matrox Computers & Internet Experts
David Payne
David Payne
Are you a Matrox Computer and Internet Expert? Answer questions, earn points and help others
