Question about Toolshopusa Retractable 25' Air Hose
Ratchet/click stops do not work,but spring still reels in,no rust or dents in any part
My ratcheting air hose reel has stopped working,But still reels up,it just will not lock in any position except fully sucked in. any ideas ? Thanks
  • 1 more comment
  • trian May 10, 2009
    Coxreels Air Hose Reel With Hose 3/8in. X 25ft....about 5 years old,made in USA, always worked great,no boing or other sound,just no ratchet stop places.
  • trian Jun 03, 2009
    I replaced the locking cam and dog spring and it works like new. (part no's-640-1-ss and 274-1-ss)
  • Anonymous Jan 17, 2017
    How do you pull the thing apart to replace those parts?
  • 142 Answers
Catch pawl in the reel is shot. I used to work in places where this happened. The only solution is tie the hose off on to a stationary object.
The only other solution is replace the reel..
Posted on Jun 03, 2009
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Fishing reel wont engage
Sounds like it needs some TLC and repair. Home
I've included a link to The Reel People. MIke can help you out.
Nov 12, 2014 | Fishing
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Sep 25, 2013 | Electrolux Band Aerus Lux Legacy Canister...
3/8 air rachet will not stop spining
The ratchet needs repair. I would check the throttle lever valve inside. Either the spring inside or the valve o-ring are worn out.
Nov 08, 2012 | Craftsman 3/8" Pro Air Ratchet Rapid...
Where do I find manuals for Shimano Tyrnos 10II reel
Hello
Get into this video
www.youtube.com/watch?v=ywf3NZG_xvU
Jan 04, 2012 | Boating
Got longer hose how do i adjust the spring
Reel are made for a size 25' 50' Etc. what you want to put 30' on a 25' REEL.?.
Jan 15, 2011 | Toolshopusa Retractable 25' Air Hose
Old Penn 209 level wind not turning but spool works is there a part missing ??
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
Aug 02, 2010 | Sport & Outdoor - Others
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Toolshopusa Retractable 25' Air Hose Logo
1,344 people viewed this question
Top Toolshopusa Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Toolshopusa Air Tool and Compressor Expert? Answer questions, earn points and help others
