Question about Garden
I hit a rock with my Toro 20331 22'' recycler ... a bunch of pieces of hard black plastic came out. It appears to have been in a curved shape before its mishap. I've looked on the Toro website but can't find anything that looks like the right part to order. I can't be the only one that's done this ... Thanks in advance
  • bbaird May 11, 2009
    Thanks for the quick response ... more indepth comparison of Toro's parts drawing and the underside of my mower made me think it is just as you surmise ... the rear baffle. I have ordered the baffle and its related pieces and am, with your response, now fairly confident I will be able to resurrect my almost brand new mower.
    Thank you very much!
    Bev
  • John C Bridgers Sr May 11, 2010
    Hello
    Have you Checked the Baffles Under the Deck?
    Are they Still Intact?
    Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
    Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
    Good Luck
    Respectfully
    jbridger (John)
  • 246 Answers
Hello Again bbaird:
I am Glad I was Able to Assist.
>>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
Best Wishes and Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
Toro recycler wont start after hitting rock
flywheel key sheared but before you make this repair... disconnect the spark plug wire, turn the mower on it's side with the muffler pointing down and spin the blade by hand while keying in on one spot to verify the crankshaft isn't bent... removing the spark plug makes this task safer and easier... did you remove the flywheel nut ??? reinstall it so it's even with the top of the crankshaft. put a prybar under the flywheel and hit the nut with a large mallet... DO NOT USE A STEEL HAMMER OR YOU RISK RUINING EVERYTHING... you can actually use a steel hammer but you have to be very careful... that's just a disclaimer :-)
Aug 29, 2014 | Toro Garden
Mower hit a rock and won't start
On most push mowers, there is a "key" that is located on the end of the crankshaft, opposite end of the blade, that drives the flywheel. It's a small rectangle piece of metal that connects the two. When the inertia of the blade stops abruptly, the flywheel acts as a safety for the engine, and shears the key. Tools are made to remove the flywheel and videos online for repair assistance. Replacement keys are specific to the engine you are working on. Hope this helps!
Jul 24, 2014 | Toro Super Recycler Super Bagger Lawn...
Toro 6.5hp 22" Recycler model#20072 Self-prpel
John, adjusting the cable would have been my first suggestion as well, there are two screws accesible from under the deck to get the black cover off (one of them is in a corner and may be hard to see). Once you get the cover off you may be able to see if you may have a tension problem, belt problem, etc. Goodluck!
Apr 22, 2011 | Toro Power Lawn Mower
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Flat front tire on toro riding lawn mower
you need to take your pliers and straighten the curved end to remove the pin and then pull the wheel off. Be sure that your bend the pin back to the way it was after you re-install the wheel. hope this helps you
Oct 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler runs like ****
You will need to disassemble the carburetor and spray with carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or the jet in carb. These portals can become blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
249 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
