Question about JVC AV-27020 TV
JVC AV27020 This set won't tune in anything above channel 47, I have checked to make sure there isn't a lock on channels, I have tried auto program, I have tried to add the channel's manually. I have made sure that the set is set to cable, and also plugged in another set to ensure the actual signal coming in is OK. When I manually add the channel say 53 (CTV Sportsnet) you can see what looks like a scrambled picture for a couple of seconds then it blue screens. Any ideas from anyone would be appreciated.
  • 93 Answers
Ok,i'm sure your tuner is defective,what you will do is try to resolder the tuner if not effective replace it with a new screen in your tv means that your blue back setting is on,and couldn't pick up a signal
Posted on Oct 18, 2007
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
I can't program channels above 13
Check your TV settings and be sure to set the tuning mode to cable (sometimes it says CATV). You will find it's set to "air" now. When set for off-the-air tuning, cable channels 2 through 13 work fine, but above that you get nothing. After you set your tuning mode to cable, rescan channels and ou should have everything.
Apr 01, 2009 | Toshiba CF20F40 TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
H25W35DT Zenith Tv locked
can you open set ups or main menu using your universal remote? if yes try to find presets, or auto program. if no, then you really have to secure the oiginal remote.
May 31, 2008 | JVC AV-20220 TV
Again JVC AV27020
Hey thanks for the feed back . The only other suggestion i have would be the tuning section is not locking in. The tuner could be your problem or there are coils such as AGC or IF could be drifting not allowing the channels to lock in . This would not be a simple fix as you would have to locate what is failling with a schematic to track it down . I would guess the coils first or something as a resistor feeding them has changed value . The tuner would be my last guess . You might want to call around to find a shop that knows this set , as some places might just start trying parts and end up being to costly to get repaired . Good luck and let me know what you find out .
Mar 15, 2008 | JVC AV-27020 TV
TV JVC av27020
Does the screen go black with the volume still working ? If so check to make sure your closed caption is turned off . If the sound turns off as well like the tv is turning off , then it might be going into shutdown. Some of these sets have had bad caps in the startup circuit . Let me know , Good luck
Mar 14, 2008 | JVC AV-27020 TV
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Timed recording
Check in the tuning or preset menu that all the channels you should be able to record are tuned in & look to see if you have set any to SKIP.
If any are set to skip unskip them.
Nov 21, 2007 | JVC HR-VP693U VCR
No jvc remote, can't access
Nothing can fully substitute for the original remote. However, I'm not too clear on why you're not able to do an auto-programming.
If you would like to replace the original remote and don't want to spend $50 or more dollars, consider this alternative:
We have just about all of these in the shop and they really do access ALL the functions of the original.
Nov 20, 2007 | JVC AV-27230 27" TV
JVC AV-27020 TV Logo
252 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
