Question about Video Game Consoles & Games
My Nintedo wii console will not connect to my hand remote. I have tried to syncronise the two together but have failed. The handset does work on another wii console so appears to be working correctly. It has been suggested that I wipe the hard drive,but I can't do this until they talk to each other.
  • christina480 May 10, 2009
    I have used another console in the same position and it works fine. This problem arose whilst trying to install our new Wii fit board. I did not sychronise these two together in the correct manner and therefore it failed. The current problem with the Wii remote arose after this and it has not worked since.
    Thankyou. Ihave followed your solutoin and have a result
    Brigadier General:
  • 3,614 Answers
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Let me know
Posted on May 10, 2009
  • micromaster
    micromaster May 10, 2009
    have you try also to connect or change a different remote from the one which is working??
  • micromaster
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds.
      After a few seconds have elapsed, plug the cord back into the wall
      outlet.
    2. Turn
      the power of the Wii console ON. When you see the Health and Safety
      screen, open the small flap on the front of the Wii console to find a
      red button labeled "SYNC." Press and hold the SYNC Button down for 15
      seconds. This will clear all the syncs on the Wii, allowing you to get
      a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at
      least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With
        the first Wii Remote you wish to sync, remove the battery cover on the
        back of the Wii Remote to find a small red button just below the
        batteries.
      2. Press and release the small red button just below the batteries on
        the Wii Remote; the blue lights on the front of the Wii Remote
        will blink.
      3. Quickly press and release the red SYNC button on the inside of the
        white flap on the front of the Wii console (picture).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED
        that is illuminated indicates the player number (1 through
        4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote
        added to the system.
Wii remote cursor hand not appearing on the screen
I am not sure but I had the same problem when I got a second remote hand set and my kids knew the answer. I first thing I would do is to ensure that you have new batteries in the handsets. Secondly there should be a small button inside the handset. I think that you need to push it to synchronize the handset to the Wii base station. I hope that helps
Nov 26, 2010 | Nintendo Wii Console
Memory wiped help
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaaaaa16
Dec 26, 2009 | Nintendo Wii Console
Wii remotes are not working
hi have you replaced the batteries and syncronised them with the wi unit
Sep 25, 2009 | Nintendo Wii Console
Handsets not responding.The lights light up at first & then go out.Options appear on screen. Have tried new batteries & checked the black receiving bar is working (on a friends system). Has the syncro
Hi there heather.
it seems that your synchronisation could have been lost, bear in mind some Wireless connections such as that of the wii can be scrambled/lose single if there are alot of electrical appliances in close proximity, as this messes with the wireless signals being transmitted.
you may just need to Re-Sync your Wiimotes which is simple. on the underside of the mote, inside the battery compartment there is a small red Button, pressing this whilst pressing the sync button on your nintendo wii should successfully sync each mote to your wii allowing you to play :)
hope this helps
Oct 27, 2008 | Nintendo Wii Console
My remote
make sure the wii remotes are syncronised to the wii. reconnect them at the home menu if u want.
Sep 04, 2008 | Nintendo Wii Console
Wii remote
mine does the same thing. all u have to do i open the back of the Wii remote where you put in the batteries. then all you have to do is press the red button in the bottom right hand corner and wha lah it is a synced!!!!!!!!!!!!!!!
Aug 06, 2008 | Nintendo Wii Console
Different handset to original wii console
What about holding the sync button on the Wii remote first, and then while still holding it, press and hold the Nintendo Wii sync button.
Dec 19, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
