Question about Samsung Televison & Video
Samsung SP42W4HBX STK392-10 Convergence problems
Before replacing the STK's I have read that you need to reset the convergence to factory settings to clear any corruption that may exist that would put the new STK's under undue stress which could damage them?
mute
183
add/erase
smode
Is tis true?
Also, when switch on my Samsung and press perfect focus I get a message 'check factory data'.
Normally, when pressing perfect focus it automatically focuses and finishes when 100% complete, except that it was only going to 33%.
Now when pressing perfect focus it doesn't do a scan at all it only gives me this message 'check factory data'
I'm just worried that I have cleared something that I shouldn't have?
Why is it £150 TO CHANGE stK392 IN uk but buy them from USA and they are less than $10?
Paul
techman
  • 3130 Answers
SOURCE: "Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Posted on Nov 09, 2007
BMW Rider
  • 232 Answers
SOURCE: hitachi 65xwx20b convergence
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Posted on Dec 01, 2007
  • 1694 Answers
SOURCE: convergence and self focus probs
Need all the facts for research = what board part # was replaced ? cost ? Do you have original board ? Was work done in your presence ? total cost ? Help me so I can help you.....T.
Posted on Dec 20, 2007
chrispurs1
  • 372 Answers
SOURCE: "check factor data" using self focus
Hi.
Not at all familiar with your tv but this sort of message comes up if you have altered eeprom settings while in engineers mode.
To put it right you will need the work shop manual to know how to reset the settings.
Maybe A tech on these forums can help you out.
http://dysonmanuals.llc.nu/
Chris..
Posted on Jan 08, 2008
SOURCE: Convergence IC STK392-110 vs STK392-110T
If you are removing a defective chip, can you just cut the pins carefully with a wire cutter and later apply heat to pull them off?
J.
Posted on Jan 29, 2008
Adjusting color,to much red and green
Reset the colors back to factory setting,that still a problems? Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 17, 2010 | Samsung HL-R4264W 42" DLP HDTV
I have a samsung hcp4752w and replaced the sub board, worked fine just need alighned in lower right corner, will not enter mute 183 power to adj convergence, will enter 182 fine. I checked all setting and...
Have You Replaced Convergence ICs,If not replace Both of them and 2 resistors 2.7ohms 1watt ICs are STK ICs big Black IC will have part number on them STK392-020. Mats Electronics has them in stock
1-800-628-1118
Feb 20, 2010 | Samsung HCP4252W 42" Rear Projection...
I have a HCL473W with a 'concave' screen effect on 2 colors??
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try Alibaba.com. If you have any more questions, feel free to ask!
Nov 08, 2009 | Samsung HCL473W 47" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Convergence problem
You will either need to order a new convergence board or a STK chip to replace the bad one. STK chips require using a soldering iron. A handy guide for this repair can be found by clicking on the link below. Best of luck and hope this answers your question.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 31, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung tv wont turn on
I had a similar problem and turned out to be the convergence board. Here is the part # and where I got it from. http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Dec 28, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence drift
Well, problem is that your TV is just too big... ;] Most probably you're looking at a job that includes replacing some STK chip on the convergence board, or the board itself. in parts a chip should be around 5 bucks, and the board over a hundred. Good luck
Jan 20, 2006 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
758 people viewed this question
Jerry Greenberg
Jerry Greenberg
