Ground circuit fault interuptors must be wired to four wires
see: http://www.do-it-yourself-help.com/gfci-outlet-switch-wiring.html
SOURCE: New Single Feed switch/outlet not working
Hi there, first what is your porous for the device? Do you want the switch to feed the outlet or do you want the switch to be independent? (switch feed outlet)---- black feed to gold screw on switch. then from lower screw on same side to outlet (this should be black also)> remembering to tie neutrals with wire nut in rear with pig tale to switch. hope this helps.
SOURCE: wiring switch and GFCI outlet tandem, so that
There should be 2 screws at the top that say LINE. This is where you connect the power wires. The 2 screws at the bottom should say LOAD. That is where you connect the second outlet.
SOURCE: I am replacing an old intermatic model EJ341
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
SOURCE: Cooper Industries Cooper Wiring 274W Switch and
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
SOURCE: We are trying to install
You are installing a combo device with switch and outlet.
The outlet is tamper resistant so a child cannot stick a key into outlet and get shocked.
For the outlet to work, a 2-prong plug must be inserted.
Wiring the device:
Electricians don't guess, they test.
Device has different colored screws: dark, silver and brass.
Separate wires for testing.
Do not unwind wires that are twisted together.
White wires that are twisted together and located in back of box are included in testing.
Use ordinary 2-lead tester.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire connects to dark screw.
Hot is identified.
Test Hot wire to all other wires, except bare ground wire.
Tester lights up on Neutral wire. Neutral connects to silver screw.
If you do not have a Neutral wire, then outlet will not work for that location.
You can get the outlet to work by connecting bare ground to silver screw, but that is violation of code.
Last wire goes to Load (light, fan, motor).
Load wire connects to brass screw.
In your case, this is red wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
