Question about Dishwashers
Kitchenaid KUD124SE DISHWASER SUDDENLY STARTED MAKE A GRINDING NOISE DURING LAST DRY CYCLE. TRIED RINSE AND ALL I GOT WAS GRINDING NOISE. BELIEVE IT TO BE PUMP. NEVER WORKED ON ONE. FIRST ALL IS IT MOST LIKELY THE PUMP AND IF SO HOW HARD TO REPLACE? tOM
  • 221 Answers
You most likely have either a piece of broken glass or hard food debris in the pump. There is a cutter within the pump designed to grind food debris and flush it away. However, you can take off the lower wash arm, remove the (recessed) screws from around the upper pump housing. Remove the housing (noting it's position) to clean out the pump and reassemble. **Remove power to unit prior to attempting repair.
Posted on May 10, 2009
    New Friend:
I had the same problem but i now have no power as well and the dishwasher will no longer work. Help
Posted on Jan 02, 2013
  • Robert Herdlein Jan 03, 2013
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Kitchenaid kud124se diswasher manual
The owners manual can be found at http://www.manualslib.com/manual/722766/Kitchenaid-Kud124se.html#manual. If you remove the bottom panel there is a service diagram tucked in a plastic sleeve that is affixed to the back of the panel (the L shaped panel, not the flat one).
Oct 03, 2012 | Dishwashers
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Loud grinding/scraping/rattling noise at rinse cycle
The balance sensor is likely failed.
Check the shock absorbers and springs for breakage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Grinding sound from washer
the pully is the drain pump they can go bad or may have somthing in it, pump is not bad to replace part us usually 40 -60$ , you could burn belt up and be forced to replace it also, but if you replace pump would not be a bad idea anyway belts are 20-30 $
Mar 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dishwasher Drying Problem
rinse agent is essential and best to use seperate detergent and rinse aid and not the combined tablets. if you live in a hard water area, essential also to use salt. the dishwasher will dry quite well - it relies on the last rinse being hot and then the water just evaporates. most dishwashers work like that but some turn on the element for short periods during dry.
Mar 29, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
649 people viewed this question
Top Dishwashers Experts
