Question about Intel Motherboard
Motherboard DP35DP Installation Problem
I just installed the Intel DP35DP with an Intel Core Duo processor, I also added the required DDR2 RAM. I also upgraded the power supply.  When I turn on the computer nothing happens.  The monitor says No Video Detected and the USB ports don't work (i.e., I plug in any USB device like my lighted keyboard and nothing happens).  I also have a new GeForce 7600 PCI-E graphics card.
The first time I turned it on after installation the initial Intel screen asking me whether I wanted to use F2 to configure the system. I couldn't do it because my USB keyboard, USB mouse, etc doesn't work. When I powered off and on again I get absolutely nothing but the blank video screen.
  • TonyBuenger Oct 12, 2007
    Unfortunately the DP35DP doesn't come with PS/2 connections for the mouse and keyboard. Strictly USB.
    Scholar:
  • 116 Answers
Wow ;) LOL
So you wont need USB drivers in dos. Your bios will enable usb support on its own. It is called USB/Legacy support.
As for the system not booting. Your keyboard wont stop it from booting.
So lets start with some basic TS Steps.
First: Remove any extra perfiral devices. (keyboard, mouse, expansion cards, modem, hdd, cd rom. Everything) You want NOTHING connected.
ONLY Connect,
Power Supply
1 Stick of Memory
CPU w/ CPU Fan
Video Card (be sure to plug in the card to the PCI-E power as well)
Still get nothing?
Disconnect the power, remove the CMOS Battery, and wait 5min. Plug it back in and see what you get.
Report back and we will get you going.
Posted on Oct 12, 2007
    President:
  • 317 Answers
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
3 Suggested Answers
enuro12
  • 116 Answers
SOURCE: Motherboard Installation Problem
How annoying... I guess my last message didn't make it.
So lets start with what you got. Forget the USB problem. Your pc doesn't get to that point.
Here are the things you should do.
First
Remove ALL extra devices connected to the pc including:
Hard drives
Cdroms
Modems
Expansion cards of any kind
The ONLY thing that should be connected is:
Power Supply
CPU
1 Stick of Ram
Video Card
Next
Now REMOVE the Power Cable from the PSU
Remove the BATTERY from the main board.
Let it sit for about 5minutes.
Now
Place the battery back into the board
Plug in the pc
Press the power button
What happens?
Do you get any message on the monitor now?
Sounds ?
Anything?
You should get at minimum another chance to press F2 and reset the bios.
Post your results and we can get you going.
Posted on Oct 13, 2007
  • 231 Answers
SOURCE: Motherboard Installation Problem - Intel DP35DP
Hi, the best solution I see is to log on to the makers website locate the download and support for your board and download the manual [usualy in PDF] and also a copy of your boards drivers.
I had to do exactly this with an Acer board with USB mouse & keboard sockets.
Regards mistyman
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Jan 11, 2011 | HP Computers & Internet
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
9600 gt compatibility with ddr2 RAM
sure, the only thing that matters is that you have a PCI-E slot, which you do. You processor is plenty powerful so enjoy your games.
Alex
www.CAS411.com
Mar 17, 2009 | Computers & Internet
Still Doesn't Work
You needed to configure bios (F2) when you first installed the processor,
now the Bios hangs before anything can happen,  You need to remove the Bios Battery (looks like a coin on the mobo) for about 30 secs (with the power disconnected)  then re-insert the battery and power on.
you should get the same power on message as you did the 1st time (maybe with a missings settings error too but this is expected)
Enuro12 is right about legacy USB in that your keyboard should work in BIOS (setup)
Oct 12, 2007 | Intel Motherboard
First
Hard drives
Cdroms
Modems
Power Supply
CPU
1 Stick of Ram
Video Card
Next
Now
Plug in the pc
What happens?
Sounds ?
Anything?
Have you tried clearing the CMOS, and rebooting with a standard keybord and mouse. ? (non usb)
Intel Motherboard Logo
285 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
