Question about GE 30 in. Profile JP989 Electric Cooktop
GE Profile Cooktop, F114 Error Code
GE Profile Cooktop, produces an error code of ''F114''. What does this indicate???
5 Suggested Answers
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
SOURCE: error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Posted on Sep 06, 2008
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
SOURCE: f113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Posted on Feb 06, 2011
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
GE F105 error
According the service guide, an F105 error is "Zero cross failure"
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4)If fault persists, replace main (Logic) board and recalibrate elements.
Mar 31, 2013 | GE 30 in. Profile JP939 Electric Cooktop
Error code F104
F104 is logic board (main board) MUX failure.
Action:
1) Recycle power to the cooktop.
2) If problem continues, replace logic board (~$250 part)
You can read my other entry as to how to open the unit. It seems strange that the board would fail simply from moving. That is assuming that it was properly reconnected electrically to an appropriate circuit. It is certainly worth opening up the unit and simply checking all cable connections to the board and looking for any visible damage (not that there will always be some for a failed board) before paying for a replacement.
I should point out that GE's troubleshooting instructions often end quite quickly in logic board replacement. Either they anticipate a lot of failure of these boards or they like selling replacements whether necessary or not.
Nov 02, 2012 | GE 30 in. Profile JP939 Electric Cooktop
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
I get an error message F113 for one burner
This indicates failure (open circuit) of the left front temp sensor. You can search for my solution for replacing a element on a JP939 and JP969. Will likely require replacement of the element (~$160).
Mar 24, 2011 | GE 30 in. Profile JP939 Electric Cooktop
F113
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Error code
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
GE 30 in. Profile JP989 Electric Cooktop Logo
647 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
