Question about Acer Aspire 5100-5033 Notebook
External display problem
When I hook up my acer aspire 5100 for external display to my samsung tv the screen starts flashing and will not stop. I have tried restarting with display cord already attached. Nothing works.
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
I am trying to connect my acer aspire 5100 laptop to my HD tv i have olso a vga cable when i connect it and go to tv menu and connect computer the tv screen show there are no signal can some one help me...
Make sure you have used the FN + F5 button to switch your laptop to external display.
Also is you are using VGA to component lead be aware that many of these dont work
Nov 19, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
Acer aspire 1500 no screen harddrive working software putting out correct start-up sounds
Try hooking the laptop up to an external monitor, use a vga cable. If the main display has died, the laptop may default a secondary if given the chance. If the laptop sounds like it boots but you can't see a screen on the external display try holding down the Fn key and at the same time tap the F5 key, this will toggle the display from internal to external. If a screen still cannot be seen then you may have lost the video processor on the motherboard.
Sep 06, 2009 | Acer Aspire 5100 Notebook
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
No display on acer 5100
hiiii ther
how r u ??
the beep u got is the motherboard diagnose for error in the video card
so even if u try an external screen it won't work
so if that ur VGA card is built in
u have to buy a new one
but 1st u should try this try to unhooke the card and clen it and hooke it back again and se what will happend if u get the beep again than it's dead my friend sorry
u take careand have fun
salammmmmmmm {bye in arabic}
Nov 20, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5033 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
