Radio controlled clock not working
I can't get my outdoor radio controlled clock to keep the correct time. The clock was a gift and I think it came from Sam's Club. The radio controlled quartz system is made by Shontek and the model is DM2720 WWVB. I've searched the web to try to find a manual but have had no luck. I do remember that there was a procedure involved above and beyond just putting a battery in it, but can't remember what it was. Any assistance would be greatly appreciated.
  • agforsyth May 18, 2009
    I have a clock that was purchased at Sams and it will not keep eastern standard daylight savings time. i have tried everything. I also do not have the manual. 'any thoughts?
  • Anonymous Mar 24, 2014
    put in new battery ..clock second hand keeps on spinning..
Pretty simple: Press reset. Clock should reset within 10 minutes.
Manually set by pressing Set and holding for 5 seconds. The hands will turn. Release when they get to the correct time.
Mine quit working after a year and seems to be dead. The movement won't do anything now with a new battery.
Posted on Jun 20, 2009
  • NeilOptimist Nov 07, 2010
    Hi I also have the clock mentioned above - DM2720 by Shontek. The hands on the clock just continue to move rapidly and will not stop at a specific time ~ and it's been 24 hours now. Any ideas? Thank you so much! Neil in Hull, Mass.
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
Outdoor display doesn't work
My clock display of the outdoor temp is only blinking and not display the the temp. I have the senser put in in outdoor window. The senser shoes the temp but is not carried over to the clock. Ive put in new batteries and have the senser in the correct distence from eachother. Why is the clock contunue blinking outdoor temp.?
Jan 15, 2013 | Audio Players & Recorders
Even with brand new batteries inserted into the Reciever, I still can't get an outdoor temperature. Why ?
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only.
www.serendipity-gifts.co.uk
Jun 19, 2012 | La Crosse Radio Controlled Atomic Clock
I can't set the clock. The hands keep turning and
Look at the bottom right of the back of the clock and find the "M Set" button. Simply hold it down and the clock will move (very slowly). When it gets to the correct time, let go of the button. After that, the radio controlled shoul dcontrol should correct any minor differences in time.
Jim
Mar 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
Clock is losing time
This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.
Feb 16, 2009 | Emerson Smartset Clock Radio
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
Day light Savings time problem
Hi ... I have the same problem ... I found this link but I haven't tried it out yet ...
http://www.emersonradio.com/dst_g2.htm
Oct 27, 2008 | Emerson Smartset Clock Radio
Rp5430 clock radio aut time set not working
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
Dec 25, 2007 | RCA RP5430 Clock Radio
4,397 people viewed this question
 Grubhead
Grubhead
