Question about Acer Aspire One Netbook 8.9" Notebook
Touchpad Click Buttons do not work, USB Mouse does, Fn+F7 is not the issue
Acer netbook D150 Touchpad click buttons stopped working. USB mouse works fine, then removing mouse enables touchpad click buttons to work. BUT, on restart the problems begins anew....
  • Anonymous May 12, 2009
    One one the click-buttons (on the right hand side) works well for me, but the other doesn't. Also, the touchpad works, but I can't tap or click!
    Any solution?
My mouse and think pad do not work
There are 2 possible answers to this common issue, the first is that the aspire has a mouse lock. check your keyboard on the function buttons for a picture of a mouse with a line though it, hit function and at the same time press the mouse with the line through it and if its locked off this will turn if back on. The second answer is driver issues, if the first suggestion dont work I would go to the Acer website click on downloads and drivers and enter your model number. Then download and install your think-pad and mouse pad drivers and install.
Sep 04, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do I turn off the touch pad on my Acer Aspire 5742 laptop
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 01, 2011 | Acer Aspire 5742 Notebook
Touch pad and mouse butons don't work at all.
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there’s no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Vista
Go to Control Panel> Mouse> Settings tab of the device
Click <Enable> (or <Disable> to disable)
Please go through this image, will help you..
Notes:
On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
You can click Reset device if neither of those solutions will work. ..
Please revert for further clarification....
Jan 16, 2010 | Acer Aspire One PC Notebook
My acer 5532 touchpad has suddenly stopped working... any ideas? mouse doesnt move and usb wireless mouse doesnt work either.. although it does on myu sister's laptop
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
Nov 15, 2009 | Acer Computers & Internet
Complete mousepad failure.
Do you have an option to turn the touchpad on ie and "f" key?
I expect you have turned it off
Sep 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mouse or mouse buttons will not work on acer 5315
Check to make sure the touchpad hasn't been disabled. You have a shortcut for disabling/enabling the touch bad which should be fn(Function key) + F7
Sep 17, 2009 | Acer Aspire 5315 Notebook
Acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Jul 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
786 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
