Question about Refrigerators
2006 ge side by side model 22
Defrost is not working, motherboard has no wiring diag. Just want to make sure before ordering a new board that its in fact the board and not the defrost strip.
  • 1,543 Answers
Rarely is a defrost problem caused by the mother board. (but it can happen) The most common cause is the glass tube defrost heater. I'd unload the freezer section, take the evaporator cover off (ie: the back wall of the freezer section) and ohm test the defrost heater at the bottom of the cooling coils. (ie: the evaporator) To do this, remove the push on wires and see if you get a ohm reading. Sometimes you can visually see a bad defrost heater, but the resistance check is your definitive test. You did not list your model number, so I can not list a part number for you. A defrost issue can also be cause by air leakage, such as a poor door gasket or a door which was not completely closed.
Posted on May 10, 2009
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
GE Adora model #DSS25KSRASS side-by-side - the refrigerator side is not staying cold and periodically quits working
This is a very common problem that comes with your model refrigerator. I need you to pull the refrigerator away from the wall, unplug power, remove the panel covering the compressor and feel the top of the compressor. Is the compressor too hot to keep your hand on the top? What I believe is happening is the control board or the start components are defective causing the refrigerator to cool off and on or periodically as you said. The solution may require a new control board=> WR55X10942 Main Control Board
and new compressor start components=> WR62X79 Run Capacitor
and the=> WR07X10057 Start Relay
Should you choose to repair your refrigerator I will happy to answer your questions. This model GE refrigerator has caused many complaints because of the expense and frequency of this type of repair. Many home owners are better off with a refrigerator that does not have a motherboard and uses simple defrost timers or defrost control boards. Here nis a link to a=> DSS25KSRASS Service Manual
GE ARTICA PROFILE TECHNICAL INFORMATION If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | Refrigerators
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
Please help my side by side ge refridreator is
It sounds like the main control board is bad , IF , there is no frost on the inside rear freezer wall . The old board ( yours ) is under a factory recall . I would suggest calling GE factory service , to have this replaced under warrenty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new board part number is WR55X10656 .
If there is a frost build up , then that would be a defrost problem , with a different solution . Please reply back , if that is the case .
Nov 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is working and refrigerator side is not work.
Most times that is a sign of a defrost problem. And because yours has the defrost board made onto the mother board we will need to do some looking around for the problem. Unplug refrigerator and pull away from wall. On back there is a cover over an area that contains the mother board. With power off take the board loose and examine the board for burn marks, sign's of heat or melted away solder connections. If the board looks OK the return it to its place and remove the rear panel in the freezer section. Need you to disconnect one end wire on the defrost element/heater. Check continuity through the heater to make sure there is no burnout. The defrost thermostat is connected to one end of the defrost heater. The contacts are open when the temperature is 50 degrees or higher, so testing it would look bad above 50 degrees. Just look to see if there is any deformity. If defrost thermostat is defective it will not allow the defrost heater to engage or to remain on long enough. Let me know what you fins. Sea Breeze
Jun 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Where is the defrost timer located on GE model# GSS20IEMDWW side by side refrigerator? My freezer works but the other side is warm. I took the freezer panel off and it had a thick layer of frost...
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Jun 04, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Freezer won't defrost, coils full of ice.
Dave, you are throwing me a little here. By jumping line to defrost you should have 120 V. at the heater. J-11 to j-9. Are you measuring voltage? Lets ohm out the circuit. Unplug the refer and disconnect the blue connnector from the main board. Measure between the blue wire on the connector and the orange wire on J-7 pin 9. This is right to the right. You should have approx 22 ohms. If you don't have this the problem lies either in the heater, harness,or defrost T-stat. The Tstat sits on the evaporator, opens at 140 degtrees and closes at 110 degrees. So it should read closed. Let me know how you are doing, Catriver
Jan 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
May 29, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
