Inside on the right the piece of board/Filter has broken Can it still be used
The piece of filter on the right hand side inside has broken Can the microwave still be used
  • Frank Zhang
    Frank Zhang May 11, 2010
    is it capacltor broken? what brand model yours lcd monitor? please let me know
  • 180 Answers
You have to replace the part ( Wave guide) after that use the oven
Posted on May 11, 2009
How i do replease cabin air filter
Open your glove box, remove the little shock on the right side
take your hands on both sides of the glove box and squeeze inwards to collapse the sides of the box at the same time as pulling outwards. The glove box will come out or drop down. Behind there is a small cover approx 2" x7" there is a tab, remove it bt unclipping it and pollen filter is inside. Keep in mind there are some with a tray attached to the opening cover, make sure if this is what you have, put the pollen filter under the clips in the tray as it was or you may hear noise after. Also note, if you have leaves inside they will drop inside the fan blade if your not careful. If this happens you can either vacuume them out or use compressed air in vents to try to blow out or use your fingers, of course with it turned off for safety. I always use fingers to reach in and check anyways for leaves or debris. Good luck
Feb 14, 2015 | 1996 Toyota Camry
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
Clicking noise coming from the heater blower motor
if you car is equipped with cabin filter to filter the air entering the blower right, blower motor can be touching to sides of its housing since its bearing is broken.
if no cabin filter, probebly you have leaves or small pieces of wood coming from trees. those are touching to the surface of blades of fan inside blower motor housing.
Nov 30, 2011 | 2004 Saturn ION
The dehumidifier I have is a model AD40LBK Whirlpool. How do I clean the filter on this model.
The filter will e in one of two locations;
1. Remove the water bucket and look up just inside the bucket holder for a pull tab type handle. If you see one or two, that is the filter frame. Pull staring down on it. If you have never removed the filter before thee may be a piece of tape holding it up in place. This was just for shipping purposes. Remove the tape and discard it.
2. On the right hand side of the unit (as you face it) there may be a rectangular flip open plastic door. Behind that door lies the filter. Open the door and pull the filter straight out. Like the above, it may have a piece of tape on it. Remove the tape and discard it.
To clean the filter. you can vacuum ti using a vacuum that has a hose & brush attachment. If it is really dirty, wash it in warm water and mild dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter installed. Doing so, can damage the unit.
I hope this was of help to you and thanks for choosing FixYa.
Jul 24, 2011 | Whirlpool AD40LBK Dehumidifier
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Cant find oil filter on a 2002 alero 2.2 liter
The oil filter on a 2.2 liter...if it is an ecotec engine is right there toward the front of the engine on the right hand side. It is a cartridge filter. Just unscrew the cap, pull out old filter with the cap. Make sure the gaskets that come with the filter are replaced and snap new filter inside the cap and replace.
Jan 07, 2010 | 2002 Oldsmobile Alero
Icemaker
filter could be inside the refrigerator section upper right hand side. twist and pull down.
Jul 05, 2008 | GE GSS22JER Side by Side Refrigerator
Filter queen majestic vacuum
The cone filter if put on right should collect the dirt, the tabs shoud be on the edge so when you put the top on, it keeps it in place. Wish I could help more, guess I would have to see it to figure it out. Here is a pic. of the top part, are all filters ok? There is one under the round card-board besides the one at the bottom of the motor. #18 is the filter.
Mar 27, 2008 | Filter Queen Majestic Canister Vacuum
Computers & Internet Logo
David Payne
David Payne
