My fellowes DM65C paper shredder does not shred paper. It seems to be in reverse mode, and will not grab and shred the paper no matter which way I press the button (forward of reverse). I have tried unplugging and plugging the unit into the wall with no results.
  • iceddie2 May 10, 2009
    So, the rocking switch with the letters I O R is defective.
    Genius:
  • 1,847 Answers
This is the problem with the reverse button. Open the control panel and replace the button, that will fix the issue.
If the shredder is working in the reverse order, that means the everything is working fine except the reverse button.
Let me know if you need further assistance
Thanks
Kindly rate the answer
Kevin
Posted on May 10, 2009
  • Legin Varghese
    Legin Varghese May 10, 2009
    i dont have then exact label on the switch, but yes the one which helps you move it the reverse direction need to be replaced..
    thanks
    Kevin
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Shreder will only go backwards
I have a Fellows OS-11Cs shredder that suddenly quit operating. It would run in reverse and when auto mode was selected an audible clicking noise was emitting from a relay on the pc board. My initial thought was that I had overheated the unit since the shredder had been operating perfectly up to the point where it stopped working but that didn't seem to be the case after the unit was allowed to cool down.I cleaned all visible paper shreds from the cutters(with the shredder unplugged)that were visible and then sprayed the cutters with a very light lubricant (3 in 1 oil) I then operated the shredder in the reverse mode for a few moments and since then the shredder has operated flawlessly.I hope this is of some assistance to others with a similar problem.
Apr 01, 2008 | Fellowes 3011001 Shredder
395 people viewed this question
k24674
jasbo
jasbo
