Question about EliteGroup PF5 Extreme (PF5EXTREME10) Motherboard
Noisy motherboard fan
Motherboard fan on Extreme PF5 is now making a loud hum and then after a while over heats and shust off the computer. Tried to fix with ne thermal compound but no luck. Is my motherboard shot?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please i would advise you to get a new one to replace the old fan before your motherboard get damaged
Posted on May 10, 2009
GE microwave occasionally buzzes loudly.
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Microwave Ovens
I have 880 motherboard with amd phenom quadcore the fan is to loud can any one give me an idea what fan would suit and make less noisy as its to load.
Some fans are temperature-sensitive, i.e., when the CPU is "hot", the fan spins at high-speed, with more noise. For other fans, you can restart your computer, and enter BIOS SETUP, and set the speed of the fan, e.g., 50% or 70%, to make it quieter.
Apr 04, 2011 | Gigabyte (GA-880GM-D2H) Motherboard
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
Mar 01, 2011 | Computers & Internet
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Mt dimension 3000 gets very noisy when the weather
That's because it heats up more easily and faster, which usually makes the fans spin faster and results in being noisy. Have you ever cleaned out the interior of the computer? If not, or if it's been awhile since it's been done, then buy some canned air for dusting electronics, open the side of the computer case (while it's not powered ON), and blow out the fans and the heat sink. If you get alot of just clogging up the heat sink, then it will not dissipate heat correctly; which results in the fans running more often. It that doesn't help any, then I would try to figure out if one of the fans is making alot of noise because it's going bad. You can find replacement fans on ebay, or at local electronics\computer shops.
Apr 10, 2010 | Dell Dimension 3000 PC Desktop
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
I want to download ECS motherboard driver
go to http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/ECS-PF5-Extreme-V10A-Realtek-LAN-Driver-673.shtml http://www.findmysoft.com/drivers/ECS-945GTY-M-Audio-motherboard-driver.html
Jun 08, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Cpu makes noise when play game
blown any dust out of the back of the pc?
hope i was helpfull
good luck
Mar 18, 2009 | HP Compaq d530 SFF PC Desktop
Loud cooling fan hum
If the fan was not that noisy before , this can only be cause by a dirty fan and you may need to clean it up to reduce the hum coming out from it...
Dec 28, 2008 | Acer Extensa Laptop
EliteGroup PF5 Extreme (PF5EXTREME10) Motherboard Logo
69 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
