Question about Mitsubishi WS-55511 55" Rear Projection Television
I have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking on and off. We've used the paperclip to reset the machine and it doesn't work, and we've unplugged the power supply
I have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking on and off. We've used the paperclip to reset the machine and it doesn't work, and we've unplugged the power supply for a few minutes; repowered and this doesn't reset the TV. What should I do now?
  • Anonymous May 10, 2009
    Powers off right after u turn it on! Piece of Sh--!
  • ljstavropoul May 11, 2009
    thank you - I have placed my order and will let you know if I come unglued when I try and fix this....technically challenged blonde brain and all!
  • Mitsubishi Master
  • 8,617 Answers
Replace the capacitors on the DM board. Heres a link to the repair kit which contains the replacement capacitors and instrucions of how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 11, 2009
  • Sonny Berry
    Sonny Berry May 11, 2009
    Its avery easy repair, and the instructions are good so you shouldnt have any problem and the soldering that is required is very basic nothing difficult.
I have a Mitsubishi WS-55511..my convergence ic is probably blown. Is this an easy repair?
Posted on Oct 19, 2009
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
I also have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking wildly. We, also, have used a small wire to reset the set and it isnt working. We have also unplugged the power...
Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
part # 181P734030 (680 uFD, 16V, 105C).
Nov 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tip
I hope that helps.
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
1,975 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
