Question about RCA F38310 38" TV
No picture/no sound. fan working
Hello, I have a model F38310 hdtv. Last night i lost picture and sound. The fan is still running but all other functions are dead. Please advise how I can get this fixed. I hate to give up this set. It's great. Thanks mijsegs
    Problem Solver:
  • 10 Answers
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
Posted on May 12, 2009
Samsung, no picture or sound
The power supply regulator board to your tV should be troubleshooted. Sometimes, it might have to be replaced as card basis. Seek tech support.
Jun 25, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hi i am a retired engineer but have a samsung sp50l7hxx all these models have the same fault -overheating -causing no picture with sound , then reset and stays ok for up to 1 hour to many engineers...
Since you are an engineer (electronic i hope) most electrolytic capacitors have a temprature rating.
I noticed this on a replacement board my local repair shop offered me. 85deg C on mine vs 105deg C on the replacement boards.
What I did on mine was to replace them all with the same uF value and same voltage, but with a higher temperature rating.
I also added 2 small fans in the case, and tapped it from the 12V supply. (I used VGA card fans from my local PC shop)
It solved my problem. If you are comfortable doing this you should have a working solution, alternatively you can ask you local TV HiFi shop do do this too. Was a lot cheaper than replacing the boards.
Hope this can help you too.
Mar 01, 2010 | Samsung SP50L7H 50" HDTV-Ready Television
My whole house fan froze up last night..it hums
Call a professional it sounds like your squirrel cage fan has lost a bearing or broken a support component.
Jul 08, 2009 | Dryers
Toshiba 50in plasma
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
JVC Rear Projection
If you still can see the DirecTV guide and menu, the problem could be on your satellite receiver and not the TV. Unplug your receiver and plug it back.
If the rebooting did not work, I would suggest to swap the satellites receivers and see if it works.
Good Luck.
Mar 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
No Picture
This is quite often a dodgy connection
Check that all leads and scart cables are in correctly
Feb 29, 2008 | Hitachi 51F500 51" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
RCA F38310 38" TV Logo
196 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
