Question about HP PSC 1315 All-In-One InkJet Printer
Printing background I am trying to print a form on Excel. It prints my headings but not the cell lines. I am using XP Pro New cheap printer HP Deskjet F4140 I remember back in using 95 Windows it had a feature to chage whether to print back ground or not. I do not find that feature on XP Pro. Probably just do not know where to look. Thank you for your help e-mail address:
  • 1,601 Answers
This is actually a setting within the Excel application object embedded in the
document. Double-click the worksheet object, then Tools/Options/View. activate
Posted on Dec 01, 2007
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro 8500 Printer does not print the last line
Try uninstalling the driver and reinstalling it by going to HP's web page. Before doing so, defragment your C drive.
Oct 22, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 When printing a power point presentation, lines are printing over the jpeg pictures on the slide
There is some problem with your print heads. Run a print diagnostic report and see if it helps. You also may want to trigger clean cartridges if triggering print diagnostic page does not help.
This issue may happen if the printer is not used for few days. Recommend to keep the printer powered on always, or then trigger print diagnostic page as it tries to unclog the blocked print heads to give you a clean print.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP4000n (Not printing borders on Excel and Word)
this is because your document content is out of range for your printer settings
clik on file - page setup and adjust your document properties from there
Jul 24, 2009 | Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP 4700 not printing excel files correctly
Only solution I've found is to print to pdf, then send the pdf to the 4700. pdf995 works quick & cheap
Jan 19, 2009 | HP LaserJet 4700 Printer
HP L7780
Clogged Inkjets? Could they be white Lines in your prints? Assuming your inkjet printer worked OK before a period of non use? And you do not have any strange flashing lights, or an obvious electrical fault or malfunction?
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like WARMED Magic Inkjet Flush
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realising the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and WARMED Magic Inkjet Flush injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Hope this helps to explain.
Apr 29, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Do you know how to setup the fax machine to print a confirmation page after each fax job?
How to adjust the top margin of my print out ?
I need to do some adjustment and my New HP 3050 printer is not cooperating. Usually,I enter info to my Microsoft Excel ,later print it out. I need the words to print at exact places because I need to fill info into forms.
A regular task I had been doing with my old printer but the
HP 3050 printing just can't be instructed to do the same.
Mar 13, 2008 | HP LaserJet 3050 All-In-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
