Question about Philips HDD1630 MP3 Player
Battery hi, umm i plug in my hdd1630 in the charger for the recommended 4 hours of charge. but after about 2 hours the battery indicator shows the batter is full, but i leave it on until the four hours are up. after that it seems as if the player plays for about four hours only. after that it says that the batter is almost out and needs to be replaced. can someone please help me with this problem?
    Problem Solver:
  • 11 Answers
Re: Battery
Uhm.. Do you plug it up to your computer to charge? Mine is old and dies after about two hours.. I know I need to replace. But in it's old age I guess (Bought from ebay) it won't charge connect to my computer.. So, maybe if you haven't tried already, to try that. Though, sounds like it's getting old like mine and will need a new battery soon.
Posted on Nov 26, 2007
0 characters
3 Points
Battery won't charge
when you connect it to computer is it showing as hardware detected?
Feb 05, 2008 | Philips HDD1630 MP3 Player
My ematic wont will not work unless its on the charger
Hi, what causes the ematic won't will not work unless its on the chargeris because the battery cell powering your Mp3 player is too weak to power up the Mp3 player.
That's why when you plug in the charger it powers on , but can not charge up the battery because the battery cell is down..
When you replace the battery, make sure you charge battery for a list 4 to 6 hours before use, cause a new battery comes with a factory battery power of about 50to 60 %, but not up to100%.
So for the cells in the battery to function properly, you will need to charge battery to100% full.
Feel free to pass your comments.
Thanks for using fixya....
Jan 10, 2011 | MP3 & Digital Media Players
I have two ipod video's a1099 and a1059, They were dead wont turn on wont charg,, I got two new battery's The a1099 came on with new battery and had about 1/2 a charge, charged it last night just...
Hi, answer a little bitlong, you can use this links to reset the ipod.
Hope it helped. await your comment.
Take care.
Jun 06, 2010 | MP3 & Digital Media Players
How do i know if it is charging? just got a shuffle of a mate, put it on charge for a few hours, but not getting anything to happen. hope you can addvise me.
when u connect ur charger with power plug or connect pc via usb cable then it indicate ur battery meter indication is charging continue but if doesn't show anything then plz check ur usb/power cable. if it is damaged then change it.
Jul 30, 2009 | Apple iPod shuffle MP3 Player
Ipod nano 8gb Low battery Life
Umm i have heard that you are supposed to charge completely before you use them, also the more you charge it when it is low the less life it will have...
Jan 08, 2009 | Apple iPod nano
If the device charges when connected to the computer directly, then the battery is ok. If that's the case, are you using the charger that came with the iPod? Earlier chargers (2004, 2005ish) will not charge newer iPods.
Dec 04, 2008 | Apple iPod MA446LL/A MP3 Player
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | MP3 & Digital Media Players
60 GB iPod won't recharge
probably, when you replaced the battery, you didn't properly inserted its contact to the board connector, so just open the ipod again and re-install it, make sure it's all the way down into connector
Aug 19, 2007 | Apple iPod MA446LL/A MP3 Player
Screen says battery is full, but wont turn on
I read somewhere that even with a functional lyra, when it displays "battery full", you should keep charging for another hour. This is said to extend battery life and give you an extra 2-3 hours of power. Either this is perfectly normal, or it indicates that the battery reading tends to be inaccurate. In any case, try leaving it charging even after it gives you the message. Another thing to consider is, how long has it been in the box? I'm not sure about lithiums, but most rechargeables I know live longer when used. Live it alone for too long and you shorten it's life. Could be good to get a second opinion on this battery thing though. If there's a warranty, don't let it waste. Good luck
Jun 20, 2006 | RCA Lyra RD2840 MP3 Player
Philips HDD1630 MP3 Player Logo
82 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
