Question about Kitchen Ranges
Oven button says off
Have Frigidaire electric range.When we hit the oven button to set temp. the screen says off. Please help
Try unplugging it and plugging it back in. I had a similar problem after I lost power once. This fixed it.
Posted on May 30, 2009
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
My oven wont shut off and gets very hot way past set temp what up with this.
Good Morning Friend,
I understand that your Frigidaire electric oven, model# es 200/300, will not shut off. I also see that it gets very hot, way past the set temperature. First, make sure you have not put it into the self-cleaning cycle. If it is not in the self-cleaning cycle, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I hit bake & it says off. I can't get the oven 2 say anything but off. Usually I hit "bake" & then up arrow 2 set temp but now as soon as I hit 'bake' or anything else it says '
Power reset it from the circuit breaker and if this does not help the control panel become more adverse to your selecting, then contact a professional. Sounds like the control board is going out.
Dec 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have an identical problem with a FEF352CATB.
There is a possiblity the oven thermostat may have to be repaired or replaced
Sep 01, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Hit the clean button while oven door was open
Need 2 people. Turn off power to it. Hold in door light switch. Turn on power. Hold switch until latch stops moving. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire FEF336BC Electric Kitchen Range
How do I calibrate a frigidaire electric oven?
On most ovens, set the oven temperature to either 500 or 550 degrees. Press and hold the bake button until the display changes. (5 to 10 seconds). then press the up/down buttons to adjust the the temp between + 30 to - 30 offset.
Jun 04, 2008 | Frigidaire Kitchen Ranges
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Setting the correct time on the clock
If you could send me a picture of the control I can show how to set the clock for sure. Usually on frigidaire you will hold down on the clock button (may be a picture of a clock) until it blinks and use the up and down arrow buttons to change the time. When the time is set hit the clock button again.
Nov 11, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
