Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Can'r pull the cord on my pressure washer. it seems to be ceased.
I pull on the cord to try and start my pressure washer. It start to pull it and then stops like it is ceased. How can I fix this. Have not used it in a year, I checked the fuel, the spark plub and the oil. All of those are good. We had the same problem and followed Mr. FixIt's solution. It helped, but now we can't get the washer to stay running. The flywheel turns and the engine starts up but won't stay running long enough to get warm. Mr. FixIt, can you help us some more? Any suggestions?
  • 15 Answers
SOURCE: I have a Briggs & Stratton gas power washer. This
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Posted on Apr 23, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
  • 174 Answers
SOURCE: Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
Posted on Sep 20, 2009
  • 15 Answers
SOURCE: craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Posted on Feb 10, 2010
Biggdex35
  • 333 Answers
SOURCE: Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
Posted on May 24, 2010
Pressure Washer ceases up upon restarting.
take the pump apart and clean up all the valves
Mar 23, 2012 | Garden
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
Cannot pull start pressure washer. Cord will not
cord will not extend past 3 inches; just shut down after last use after 30 seconds.
Aug 31, 2009 | Garden
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Jun 21, 2009 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
219 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
