Can't replace daisy wheel on Smith Corona 100 typewriter
In attempting to replace the daisy wheel (Smith-Corona 100), I find that the "slot" referred to in the instruction manual is obstructed by the brass-like spindle that is supposed to go into the center of the daisy wheel. It would seem that the ribbon deck mechanism should be movable or re-movable but I don't see anything that could change it's position, or a way to take it out. Can y ou tell me how to adjust the "slot"?
  • 3 Answers
There should be a silver tab like button you can push down to change the position of the carrier; but my problem is getting the plastic piece to fit back in there correctly after I took it out. Tried to operate without it and it will not work.
Posted on Jun 15, 2009
How to change a daisy wheel and line it up
remove the ribbon to see better. Their is a latch right by the print wheel. Just pull gently toward you and the printwheel holder will pop open. Then lift the wheel out and install the new wheel, Then push the latch back towards the platen or big black roller. It should line up by itself when you turn the power back on.
Dec 29, 2009 | Smith Corona Wordsmith 100 Typewriter
I well like to know about the printer of typewriter 5A-1 Smith corona
All SL-500 series use a plastic Daisy-wheel activated by a solenoid. This strikes a carbon coated film which leaves an impression on the paper without breaking the fibers. This allows for character removal with a tack-less correction tape when struck by the same letter through the tape.
Does this Help?
Oct 04, 2009 | Smith Corona Office Equipment & Supplies
My typewriter is a Smith Corona Word Smith. I cannot get the daisy wheel to align
From the manual of Sr Smith Corona WordSmith 100:
Changing The Print Wheel
1) Move the print carrier to the center of the platen using the SPACE or BS
key.
2) You will see a lever on the right side of the carrier. Pull this lever toward you and
lift out the daisy wheel.
3) Place the daisy wheel into the slot with the characters facing the platen.
4) Push the lever back into position.
5) Press the CODE + = (SETTING) key.
Here is the link for the manual:
http://www.google.pt/url?q=http://www.smithcorona.com/pdf/WS100Man.pdf&ei=26RzSrjIFZmOjAer4KS9Bw&sa=X&oi=spellmeleon_result&resnum=1&ct=result&usg=AFQjCNHgeBMa_etCetMv9Vq-BDehtTGprQ
Jul 31, 2009 | Brother GX-6750 Typewriter
Smith Corona SD 250
I have a Smith Corona wordsmith 250. The Daisy wheel is not aligned with the striker, it is two characters off. How do I fix this alignment??
Mar 26, 2009 | Smith Corona Wordsmith 200 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
Print Wheel Drive Gear is out of Position
Power up the machine, the "V" groove of the hammer should be center aligned with the "." petal If not 1 remove the ribbon bracket 2 loosen screw of the daisy wheel (element) motor it has locktite on it , slide the motor up or down in its slot until the hammer and petal are aligned. If you cannot correct it this waydue to a lack of travel it becomes a more complicated job may need a typewriter repair man.
Aug 02, 2007 | Smith Corona Wordsmith 200 Typewriter
62 people viewed this question
k24674
