Question about Canon ZR500 Mini DV Digital Camcorder
Canon rz500 3 purple lines appear during playback???
Camera works perfectly well but when I try to play back the footage on ANY tape there are 2 solid, light purple lines across the screen during the whole playback.
What are the purple lines and how do I get them off????
  • 128 Answers
SOURCE: Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Posted on Feb 16, 2006
  • 37 Answers
SOURCE: Playback STD Locked Playback is Restricted message
the tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Posted on Nov 06, 2008
  • 10 Answers
SOURCE: 5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Posted on Nov 28, 2008
zohail
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
SOURCE: Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Posted on Jun 25, 2009
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Nov 05, 2008 | Canon XH A1 Mini DV Digital Camcorder
Panasonic PV-GS39---playback problems
You better take in to get it serviced. It could be the take motor or a head adjustment needed.
Jun 13, 2008 | Panasonic PV-GS39 Mini DV Digital...
Playback problems - timer stays at zero
Firewire transfer problem with PV-GS320. HAd bought the PV-GS90 and ran into significant transfer issues importing to Mac (iMovie and Fincal Cut Express HD both had problems). Upgraded to GS320 as Macworld rated it highly. Same problems: video plays back perfectly with no computer connection. once connected, video and audio stutter, go out of sync, sometimes just stop and/or crash the program.
I've used a borrowed Canon GL with this Mac before with no issues, so I suspect the camera. Have tried reset button, trashing preferences, restarts, the works. still can't get clean video to transfer from a brand new camera. Any Ideas?
Feb 09, 2008 | Panasonic PV-GS320 Camcorder
Purple and green digital lines across film
One of the units is not making good interchange in recording (CAMCORDER) or (PLAYBACK) DSR11 deck either buy or get a known good recording to isolate the bad unit. Camcorders are notorious for loss of interchange as the cassette compartment wears out the scissors jack elevator gets sloppy and changes the angle of attack on the drum and wellah a tape that only plays back in the camcorder.
Jan 18, 2008 | Sony DSR-11 DV / Mini DV VCR
Horizontal lines on playback screen
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Canon ZR500 Mini DV Digital Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
