We had to change the power box on our pc last one started to smoke due to fan dying, after getting everything back working we have no sound except the normal beep. the computer will not recognise a sound device I think everything was pluged in correctly when put back together
  • terracwc May 11, 2010
    Can you give me the Model # and make of the Motherboard / mobo ?
  • computerscot May 11, 2010
    If your computer is starting up normally, just with no sounds after it boots then I would look to see if your audio card has come loose. If it is an onboard audio card then it is possible that it could have gotten damaged from the dying power supply. Post back with what the computer is doing.
    Does it boot up into Windows?
    Does it hand during the boot process?
    If it does boot, check under Device Manager. Are there any yellow exclamation points and is your audio card found there?
  • 433 Answers
Speaker (right speaker) wire to GREEN socket. Open your device manager and see if any sound component is registering a splat...yellow ! Is the light on the speaker. Open sound and see that no X is in the mute box. Make sure the volume in turned up on the speaker and the computer. If all that is cool...reinstall the sound drivers for your computer. I don't mean to belittle you but its the little things that are missed can mess you up for hours-and man does it give one a red face. good luck , hope something here helps
please leave rating.
Posted on May 13, 2009
My power went of a for about 8 hours last night and when the power was restored everything works except I cannot hear sound on my BT730 sound system while listening to TV through the cable box. I can hear...
Trace the TV audio back to its source - TV or Cable Box most likely. We have no way of knowing which. Substitute in another source to test the input.
If DVD audio works so does the basic HTS.
Sep 07, 2011 | Panasonic Home Theater System System
Box was working, tv now back to analog
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Jun 18, 2009 | Insignia Digital-to-Analog Converter for...
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
I took my pc apart last night to do some kabinett mods to my antec 900. and put everything back togheter and startet up, everything seems to work but i dont get no picture on my screen, it says no signal...
"No signal input" means that the signal is not making it from your video card to the monitor. Things to try: 1) check your monitor cable to make sure you didn't accidentally bend any pins when you reconnected it. 2) Unplug the monitor for about 5 minutes and then try again. 3) If you are positive that everything is connected correctly and that things are working (you can hear the hard drive and fans spinning up but no video) then you may have somehow killed a component. disconnect everything except the power-supply, video card, 1 stick of ram, the CPU and the CUP fan and see if it you get video there. If you don't, then the next step would be to swap out each of those components left to see what died.
Jun 03, 2009 | ASUS Motherboard Striker II Formula
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
No boot up
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
Sep 25, 2008 | ASUS A7V333 Motherboard
No power except fan
It's your CPU. It sounds like you didn't apply the thermal liquid between your CPU and fan.
Mar 29, 2008 | Gateway GT4022 PC Desktop
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
